Vertex Deletion for 3D Delaunay Triangulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2013
We show how to delete a vertex q from a three-dimensional Delaunay triangulation DT(S) in expected O(C(P)) time, where P is the set of vertices neighboring q in DT(S) and C(P) is an upper bound on the expected number of tetrahedra whose circumspheres enclose q that are created during the randomized incremental construction of DT(P).
poster.pdf (808.58 Ko) Télécharger le fichier
Format : Figure, Image
hal-00963520 , version 1 (21-03-2014)
  • HAL Id : hal-00963520 , version 1
Kevin Buchin, Olivier Devillers, Wolfgang Mulzer, Okke Schrijvers, Jonathan Shewchuk. Vertex Deletion for 3D Delaunay Triangulations. ACM. Symposium on Theory of Computing, 2013, Palo Alto, United States. 2013. ⟨hal-00963520⟩
110 Consultations
153 Téléchargements
