Efficient Implementation of Applicative Languages, 1984. ,
The static single information form, 1999. ,
Modern Compiler Implementation in Java, 2002. ,
Design and Implementation of an Ahead-of-Time Compiler for PHP, 2009. ,
A practical solution for scripting language compilers, Proceedings of the 2009 ACM symposium on Applied Computing, SAC '09, pp.1916-1923, 2009. ,
DOI : 10.1145/1529282.1529709
ABCD: eliminating array bounds checks on demand, PLDI, pp.321-333, 2000. ,
Fast liveness checking for ssa-form programs, Proceedings of the sixth annual IEEE/ACM international symposium on Code generation and optimization , CGO '08, pp.35-44, 2008. ,
DOI : 10.1145/1356058.1356064
URL : https://hal.archives-ouvertes.fr/inria-00192219
Improvements to graph coloring register allocation, ACM Transactions on Programming Languages and Systems, vol.16, issue.3, pp.428-455, 1994. ,
DOI : 10.1145/177492.177575
Fast copy coalescing and live-range identification, PLDI, pp.25-32, 2002. ,
The semantics of program dependence. SIGPLAN Not, pp.13-27, 1989. ,
Customization: optimizing compiler technology for SELF, a dynamically-typed object-oriented programming language, ACM SIGPLAN Notices, vol.24, issue.7, pp.146-160, 1989. ,
DOI : 10.1145/74818.74831
Automatic construction of sparse data flow evaluation graphs, Proceedings of the 18th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '91, pp.55-66, 1991. ,
DOI : 10.1145/99583.99594
Effective representation of aliases and indirect memory operations in SSA form, CC, pp.253-267, 1996. ,
DOI : 10.1007/3-540-61053-7_66
Abstract interpretation, Proceedings of the 4th ACM SIGACT-SIGPLAN symposium on Principles of programming languages , POPL '77, pp.238-252, 1977. ,
DOI : 10.1145/512950.512973
URL : https://hal.archives-ouvertes.fr/inria-00528590
Why does Astr??e scale up?, Formal Methods in System Design, vol.345, issue.1, pp.229-264, 2009. ,
DOI : 10.1007/s10703-009-0089-6
Efficiently computing static single assignment form and the control dependence graph, ACM Transactions on Programming Languages and Systems, vol.13, issue.4, pp.451-490, 1991. ,
DOI : 10.1145/115372.115320
Principal type-schemes for functional programs, Proceedings of the 9th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '82, pp.207-212, 1982. ,
DOI : 10.1145/582153.582176
The design and implementation of a non-iterative range analysis algorithm on a production compiler, SBLP, pp.45-59, 2011. ,
Unified Analysis of Array and Object References in Strongly Typed Languages, SAS, pp.155-174, 2000. ,
DOI : 10.1007/978-3-540-45099-3_9
Polynomial Precise Interval Analysis Revisited, Efficient Algorithms, vol.3, issue.1, pp.422-437, 2009. ,
DOI : 10.1007/978-3-540-74061-2_12
URL : https://hal.archives-ouvertes.fr/hal-00414750
Taming the IXP network processor, PLDI, pp.26-37, 2003. ,
Dynamic inference of static types for ruby, POPL, pp.459-472, 2011. ,
The program tree structure, PLDI, pp.171-185, 1994. ,
Dependence-based program analysis, PLDI, pp.78-89, 1993. ,
LLVM: A compilation framework for lifelong program analysis & transformation, International Symposium on Code Generation and Optimization, 2004. CGO 2004., pp.75-88, 2004. ,
DOI : 10.1109/CGO.2004.1281665
Register promotion by sparse partial redundancy elimination of loads and stores, PLDI, pp.26-37, 1998. ,
Bitwidth cognizant architecture synthesis of custom hardware accelerators, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.20, issue.11, pp.1355-1371, 2001. ,
DOI : 10.1109/43.959864
The octagon abstract domain, Higher-Order and Symbolic Computation, vol.2477, issue.3, pp.31-100, 2006. ,
DOI : 10.1007/s10990-006-8609-1
Accurate interprocedural null-dereference analysis for java, ICSE, pp.133-143, 2009. ,
Principles of program analysis, 2005. ,
DOI : 10.1007/978-3-662-03811-6
Design and implementation of sparse global analyses for c-like languages, PLDI, pp.229-238, 2012. ,
Optimal control dependence computation and the Roman chariots problem, TOPLAS, pp.462-491, 1997. ,
DOI : 10.1145/256167.256217
Optimization of Object-Oriented and Concurrent Programs, 1996. ,
On sparse evaluation representations, Theoretical Computer Science, vol.277, issue.1-2, pp.119-147, 2002. ,
DOI : 10.1016/S0304-3975(00)00315-7
Tainted flow analysis on e-SSA-form programs, CC, pp.124-143, 2011. ,
Efficient static checker for tainted variable attacks, Science of Computer Programming, vol.80, pp.91-105, 2014. ,
DOI : 10.1016/j.scico.2013.03.012
A fast and low overhead technique to secure programs against integer overflows, CGO, pp.1-11, 2013. ,
The Hot Path SSA Form: Extending the Static Single Assignment Form for Speculative Optimizations, CC, pp.304-323, 2010. ,
DOI : 10.1007/978-3-642-11970-5_17
User-Input Dependence Analysis via Graph Reachability, 2008 Eighth IEEE International Working Conference on Source Code Analysis and Manipulation, 2008. ,
DOI : 10.1109/SCAM.2008.22
Static Program Analysis Based on Virtual Register Renaming, 2006. ,
Translating out of static single assignment form, SAS, pp.194-210, 1999. ,
Bitwidth analysis with application to silicon compilation, PLDI, pp.108-120, 2000. ,
A class of polynomially solvable range constraints for interval analysis without widenings, Theoretical Computer Science, vol.345, issue.1, pp.122-138, 2005. ,
DOI : 10.1016/j.tcs.2005.07.035
The design and implementation of typed scheme, pp.395-406, 2008. ,
Constant propagation with conditional branches, TOPLAS, vol.13, issue.2, 1991. ,
The transitive closure of control dependence: the iterated join, ACM Letters on Programming Languages and Systems, vol.1, issue.2, pp.178-190, 1992. ,
DOI : 10.1145/151333.151337
Incremental Data Flow Analysis in a Structured Program Editor, 1984. ,
