Key reduction of mceliece's cryptosystem using list decoding. CoRR, abs, 1102. ,
Quasi-dyadic CFS signatures, Lecture Notes in Computer Science, vol.6584, pp.336-349, 2010. ,
Monoidic codes in cryptography, Lecture Notes in Computer Science, vol.7071, pp.179-199, 2011. ,
Decoding Random Binary Linear Codes in 2 n/20: How 1???+???1???=???0 Improves Information Set Decoding, Lecture Notes in Computer Science, vol.7237, pp.520-536, 2012. ,
DOI : 10.1007/978-3-642-29011-4_31
Cyclic alternant codes induced by an automorphism of a GRS code, Finite fields: Theory, Applications and Algorithms, pp.143-154, 1999. ,
DOI : 10.1090/conm/225/03216
Goppa and related codes invariant under a prescribed permutation, IEEE Transactions on Information Theory, vol.46, issue.7, p.2628, 2000. ,
DOI : 10.1109/18.887871
On the cyclicity of Goppa codes, parity-check subcodes of Goppa codes and extended Goppa codes. Finite Fields and Applications, pp.255-281, 2000. ,
Reducing Key Length of the McEliece Cryptosystem, Progress in Cryptology -Second International Conference on Cryptology in Africa, pp.77-97, 2009. ,
DOI : 10.1007/BFb0019850
URL : https://hal.archives-ouvertes.fr/hal-01081727
Attacking and Defending the McEliece Cryptosystem, PQCrypto, pp.31-46, 2008. ,
DOI : 10.1007/0-387-34799-2_10
Explicit bounds for generic decoding algorithms for code-based cryptography, Pre-proceedings of WCC 2009, pp.168-180, 2009. ,
Smaller Decoding Exponents: Ball-Collision Decoding, Lecture Notes in Computer Science, vol.6841, pp.743-760, 2011. ,
DOI : 10.1007/978-3-642-22792-9_42
URL : http://repository.tue.nl/714848
The Magma Algebra System I: The User Language, Journal of Symbolic Computation, vol.24, issue.3-4, pp.3-4235, 1997. ,
DOI : 10.1006/jsco.1996.0125
Ein Algorithmus zum Auffinden der Basiselemente des Restklassenringes nach einem nulldimensionalen Polynomideal, 1965. ,
A new algorithm for finding minimum-weight words in a linear code: application to McEliece's cryptosystem and to narrow-sense BCH codes of length 511, IEEE Transactions on Information Theory, vol.44, issue.1, pp.367-378, 1998. ,
DOI : 10.1109/18.651067
Ideals, Varieties, and algorithms: an Introduction to Computational Algebraic Geometry and Commutative Algebra, Undergraduate Texts in Mathematics, 2001. ,
A new efficient algorithm for computing Gr??bner bases (F4), Journal of Pure and Applied Algebra, vol.139, issue.1-3, pp.61-88, 1999. ,
DOI : 10.1016/S0022-4049(99)00005-5
A new efficient algorithm for computing gröbner bases without reduction to zero : F5, ISSAC'02, pp.75-83, 2002. ,
FGb: A Library for Computing Gr??bner Bases, Mathematical Software -ICMS 2010, pp.84-87, 2010. ,
DOI : 10.1007/978-3-642-15582-6_17
A distinguisher for high rate McEliece cryptosystems, IEEE Transactions on Information Theory, 2013. ,
A Distinguisher for High Rate McEliece Cryptosystems, Information Theory Workshop (ITW), pp.282-286, 2011. ,
Algebraic Cryptanalysis of McEliece Variants with Compact Keys, Gilbert [26], pp.279-298 ,
DOI : 10.1007/978-3-642-13190-5_14
Algebraic Cryptanalysis of McEliece variants with compact keys ? toward a complexity analysis, SCC '10: Proceedings of the 2nd International Conference on Symbolic Computation and Cryptography, pp.45-55, 2010. ,
Security Bounds for the Design of Code-Based Cryptosystems, LNCS, vol.5912, pp.88-105, 2009. ,
DOI : 10.1007/978-3-642-10366-7_6
Shorter keys for code based cryptography, Proceedings of the 2005 International Workshop on Coding and Cryptography (WCC 2005), pp.81-91, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00078726
Implementation of McEliece Based on Quasi-dyadic Goppa Codes for Embedded Devices, Lecture Notes in Computer Science, vol.26, issue.5, pp.143-162 ,
DOI : 10.1137/S0097539795293172
An Observation on the Security of McEliece???s Public-Key Cryptosystem, Advances in Cryptology -EUROCRYPT'88, pp.275-280, 1988. ,
DOI : 10.1007/3-540-45961-8_25
A probabilistic algorithm for computing minimum weights of large error-correcting codes, IEEE Transactions on Information Theory, vol.34, issue.5, pp.1354-1359, 1988. ,
DOI : 10.1109/18.21270
Weak keys in the McEliece public-key cryptosystem, IEEE Transactions on Information Theory, vol.47, issue.3, pp.1207-1211, 2001. ,
DOI : 10.1109/18.915687
On ideal lattices and learning with errors over rings, Gilbert [26], pp.1-23 ,
URL : https://hal.archives-ouvertes.fr/hal-00921792
The Theory of Error-Correcting Codes, 1986. ,
Decoding Random Linear Codes in $\tilde{\mathcal{O}}(2^{0.054n})$, Lecture Notes in Computer Science, vol.7073, pp.107-124, 2011. ,
DOI : 10.1007/978-3-642-25385-0_6
A Public-Key System Based on Algebraic Coding Theory, pp.114-116, 1978. ,
Compact McEliece Keys from Goppa Codes, Selected Areas in Cryptography, 2009. ,
DOI : 10.1007/978-3-642-05445-7_24
URL : https://hal.archives-ouvertes.fr/hal-00870932
Compact McEliece Keys from Goppa Codes, IACR Cryptology ePrint Archive, p.187, 2009. ,
The algebraic decoding of Goppa codes, IEEE Transactions on Information Theory, vol.21, issue.2, pp.203-207, 1975. ,
DOI : 10.1109/TIT.1975.1055350
Compact McEliece keys based on quasi-dyadic Srivastava codes, Journal of Mathematical Cryptology, vol.6, issue.2, pp.149-169, 2012. ,
DOI : 10.1515/jmc-2011-0099
Information-Set Decoding for Linear Codes over F q, Lecture Notes in Computer Science, vol.6061, pp.81-94, 2010. ,
DOI : 10.1007/978-3-642-12929-2_7
Finding the permutation between equivalent linear codes: the support splitting algorithm, IEEE Transactions on Information Theory, vol.46, issue.4, pp.1193-1203, 2000. ,
DOI : 10.1109/18.850662
Efficient Public Key Encryption Based on Ideal Lattices, Lecture Notes in Computer Science, vol.5912, pp.617-635, 2009. ,
DOI : 10.1007/978-3-642-10366-7_36
A method for finding codewords of small weight, Coding Theory and Applications, pp.106-113, 1988. ,
Practical key recovery attacks on two McEliece variants, International Conference on Symbolic Computation and Cryptography?SCC, p.62, 2010. ,
