New interface
Journal articles
Improving conservation properties in a 5D gyrokinetic semi-Lagrangian code
Abstract : In gyrokinetic turbulent simulations, the knowledge of some stationary states can help reducing numerical artifacts. Considering long-term simulations, the qualities of the Vlasov solver and of the radial boundary conditions have an impact on the conservation properties. In order to improve mass and energy conservation mainly, the following methods are investigated: fix the radial boundary conditions on a stationary state, use a 4D advection operator that avoids a directional splitting, interpolate with a delta-f approach. The combination of these techniques in the semi-Lagrangian code GYSELA leads to a net improvement of the conservation properties in 5D simulations.
Document type :
Journal articles
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-00966162
Contributor : Nicolas Crouseilles Connect in order to contact the contributor
Submitted on : Wednesday, March 26, 2014 - 3:55:36 PM
Last modification on : Friday, May 20, 2022 - 9:04:52 AM
Long-term archiving on: : Thursday, June 26, 2014 - 11:00:31 AM
File
RR-8507.pdf
Identifiers
Citation
Guillaume Latu, Virginie Grandgirard, Jérémie Abiteboul, Nicolas Crouseilles, Guilhem Dif-Pradalier, et al.. Improving conservation properties in a 5D gyrokinetic semi-Lagrangian code. The European Physical Journal D : Atomic, molecular, optical and plasma physics, 2014, 68 (11), pp.345. ⟨10.1140/epjd/e2014-50209-1⟩. ⟨hal-00966162⟩
Share
Metrics
Record views
736
Files downloads
237
