Network Discovery and Verification, IEEE Journal on Selected Areas in Communications, vol.24, issue.12, pp.2168-2181, 2006. ,
DOI : 10.1109/JSAC.2006.884015
On the Metric Dimension of Cartesian Products of Graphs, SIAM Journal on Discrete Mathematics, vol.21, issue.2, pp.423-441, 2007. ,
DOI : 10.1137/050641867
Bounds on the metric and partition dimensions of a graph, Ars Combin, vol.88, pp.349-366, 2008. ,
Resolvability in graphs and the metric dimension of a graph, Discrete Applied Mathematics, vol.105, issue.1-3, pp.99-113, 2000. ,
DOI : 10.1016/S0166-218X(00)00198-0
Resolvability and the upper dimension of graphs, Computers & Mathematics with Applications, vol.39, issue.12, pp.19-28, 2000. ,
DOI : 10.1016/S0898-1221(00)00126-7
Algorithm 97: Shortest path, Communications of the ACM, vol.5, issue.6, p.345, 1962. ,
DOI : 10.1145/367766.368168
On the metric dimension, the upper dimension and the resolving number of graphs, Discrete Applied Mathematics, vol.161, issue.10-11, pp.1440-1447, 2013. ,
DOI : 10.1016/j.dam.2013.01.026
On the metric dimension of a graph, Ars Combin, vol.2, pp.191-195, 1976. ,
Extremal Graph Theory for Metric Dimension and Diameter, Electronic Notes in Discrete Mathematics, vol.29, issue.1, p.30, 2010. ,
DOI : 10.1016/j.endm.2007.07.058
Characterization of randomly k-dimensional graphs ,
On randomly <mml:math altimg="si3.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>k</mml:mi></mml:math>-dimensional graphs, Applied Mathematics Letters, vol.24, issue.10, pp.1625-1629, 2011. ,
DOI : 10.1016/j.aml.2011.03.024
Landmarks in graphs, Discrete Applied Mathematics, vol.70, issue.3, pp.217-229, 1996. ,
DOI : 10.1016/0166-218X(95)00106-2
Metric bases in digital geometry. Computer Vision Graphics and Image Processing, pp.113-121, 1984. ,
Leaves of trees, Congr. Numer, vol.14, pp.549-559, 1975. ,
Discrepancies between metric dimension and partition dimension of a connected graph, Discrete Mathematics, vol.308, issue.22, pp.5026-5031, 2008. ,
DOI : 10.1016/j.disc.2007.08.089
Estimates for the metric dimension of a graph in terms of the diameter and the number of vertices, Vestnik Moskov. Univ. Ser. I Mat. Mekh, vol.103, pp.68-70, 1987. ,
