New interface
Conference papers
Co-simulation Solution using AA4MM-FMI applied to Smart Space Heating Models
Laurent Ciarletta 1 Leilani Gilpin 2 Yannick Presse 1 Vincent Chevrier 3 Virginie Galtier 4
1 MADYNES - Management of dynamic networks and services
Inria Nancy - Grand Est, LORIA - NSS - Department of Networks, Systems and Services
3 MAIA - Autonomous intelligent machine
Inria Nancy - Grand Est, LORIA - AIS - Department of Complex Systems, Artificial Intelligence & Robotics
Abstract : Multi-modeling and co-simulation are one of the solutions for dealing with complex systems. In this paper, we propose to apply the AA4MM framework to the co-simulation of a smart space heating "complex" environment with 2 objectives. Our first contribution is the development of AA4MM-FMI (Agent and Artifact for Multiple Models coordination for FMI). AA4MM is a modeling and simulation framework that can be used to implement the "master" in a multiple FMU (Functional Mock-up Unit) co-simulation of the FMI (Functional Mock-up Interface) standard with a fully decentralized view and intrinsic coordination. Our second contribution is to apply and evaluate this solution by creating a hierarchy of smart space models that are exploiting house geometry information. Each individual room is represented as an independent FMU taking inputs of the room's geometric information (surface area, volume, insulation, etc.), target temperature, and neighboring rooms. The neighboring rooms are connected to each other using the AA4MM-FMI framework. This project aims to couple an electrical heating-based simulation with networking event-based simulations to gain intuition for how house geometry affects efficient heating and network connectivity. Using this smart space house heating problem, we are able to test AA4MM-FMI (our novel "master") for FMI and multi-simulation.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00966461
Contributor : Vincent Chevrier Connect in order to contact the contributor
Submitted on : Wednesday, March 26, 2014 - 4:24:56 PM
Last modification on : Saturday, November 19, 2022 - 3:59:07 AM
Links full text
Identifiers
Citation
Laurent Ciarletta, Leilani Gilpin, Yannick Presse, Vincent Chevrier, Virginie Galtier. Co-simulation Solution using AA4MM-FMI applied to Smart Space Heating Models. 7th International ICST Conference on Simulation Tools and Techniques, Mar 2014, Lisbon, Portugal. pp.153-159, ⟨10.4108/icst.simutools.2014.254633⟩. ⟨hal-00966461⟩
Share
Metrics
Record views
275
