New interface
Journal articles
Competition between phytoplankton and bacteria: exclusion and coexistence
Frédéric Grognard 1 Pierre Masci 1 Eric Benoît 2 Olivier Bernard 1
1 BIOCORE - Biological control of artificial ecosystems
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique
Résumé : Resource-based competition between microorganisms species in continuous culture has been studied extensively both experimentally and theoretically, mostly for bacteria through Monod and Contois “constant yield” models, or for phytoplankton through the Droop “variable yield” models. For homogeneous populations of N bacterial species (Monod) or N phytoplanktonic species (Droop), with one limiting substrate and under constant controls, the theoretical studies indicated that competitive exclusion occurs: only one species wins the competition and displaces all the others (Armstrong and McGehee in Am Nat 115:151, 1980; Hsu and Hsu in SIAM J Appl Math 68:1600–1617, 2008). The winning species expected from theory is the one with the lowest “substrate subsistence concentration” s⋆, such that its corresponding equilibrium growth rate is equal to the dilution rate D. This theoretical result was validated experimentally with phytoplankton (Tilman and Sterner in Oecologia 61(2):197–200, 1984) and bacteria (Hansen and Hubell in Science 207(4438):1491–1493, 1980), and observed in a lake with microalgae (Tilman in Ecology 58(22):338–348, 1977). On the contrary for aggregating bacterial species described by a Contois model, theory predicts coexistence between several species (Grognard et al. in Discrete Contin Dyn Syst Ser B 8(1):73–93, 2007). In this paper we present a generalization of these results by studying a competition between three different types of microorganisms: planktonic (or free) bacteria (represented by a generalized Monod model), aggregating bacteria (represented by a Contois model) and free phytoplankton (represented by a Droop model). We prove that the outcome of the competition is a coexistence between several aggregating bacterial species with a free species of bacteria or phytoplankton, all the other free species being washed out. This demonstration is based mainly on the study of the substrate concentration’s evolution caused by competition; it converges towards the lowest subsistence concentration s⋆, leading to three different types of competition outcomes: (1) the best free bacteria or phytoplankton competitor excludes all other species; (2) only some aggregating bacterial species coexist in the chemostat; (3) A coexistence between the single best free species, with one or several aggregating species.
Complete list of metadata
https://hal.inria.fr/hal-00968182
Contributor : Jean-Luc Gouzé Connect in order to contact the contributor
Submitted on : Monday, March 31, 2014 - 3:27:44 PM
Last modification on : Thursday, May 12, 2022 - 3:34:41 PM
Links full text
Identifiers
Citation
Frédéric Grognard, Pierre Masci, Eric Benoît, Olivier Bernard. Competition between phytoplankton and bacteria: exclusion and coexistence. Journal of Mathematical Biology, 2015, 70 (5), pp.959-1006. ⟨10.1007/s00285-014-0783-x⟩. ⟨hal-00968182⟩
Share
Metrics
Record views
238
