Automative engine control and hybrid systems: Challenges and opportunities, Proc. IEEE, pp.888-912, 2000. ,
Hybrid Systems: Computation and Control. Chap. Observability of Switched Linear Systems, Lecture Notes in Computer Science, pp.48-63, 2004. ,
Design of a robust fault detection based observer for linear switched systems with external disturbances, Nonlinear Analysis: Hybrid Systems, vol.5, issue.2, pp.206-219, 2011. ,
DOI : 10.1016/j.nahs.2010.10.009
Multiple Lyapunov functions and other analysis tools for switched and hybrid systems, IEEE Transactions on Automatic Control, vol.43, issue.4, pp.475-482, 1998. ,
DOI : 10.1109/9.664150
Stability analysis and control synthesis for switched systems: a switched Lyapunov function approach, IEEE Transactions on Automatic Control, vol.47, issue.11, pp.1883-1887, 2002. ,
DOI : 10.1109/TAC.2002.804474
Stability and Stabilization of a Class of Multimode Linear Discrete-Time Systems With Polytopic Uncertainties, IEEE Transactions on Industrial Electronics, vol.56, issue.9, pp.3684-3692, 2009. ,
DOI : 10.1109/TIE.2009.2026375
Passivity and stability of switched systems under quantization, Proceedings of the 15th ACM international conference on Hybrid Systems: Computation and Control, HSCC '12, 2012. ,
DOI : 10.1145/2185632.2185668
Exponential output tracking control for positive switched linear systems with time-varying delays, Nonlinear Analysis: Hybrid Systems, vol.11, pp.118-128, 2014. ,
DOI : 10.1016/j.nahs.2013.07.002
Tracking control for switched time-varying delays systems with stabilizable and unstabilizable subsystems, Nonlinear Analysis: Hybrid Systems, vol.3, issue.2, pp.133-142, 2009. ,
DOI : 10.1016/j.nahs.2008.11.004
Robust output tracking control for switched systems under asynchronous switching, Nonlinear Analysis: Hybrid Systems, vol.8, pp.57-68, 2013. ,
DOI : 10.1016/j.nahs.2012.10.003
Barrier Lyapunov functions for the output tracking control of constrained nonlinear switched systems, Systems & Control Letters, vol.62, issue.10, pp.963-971, 2013. ,
DOI : 10.1016/j.sysconle.2013.07.003
A Descriptor System Approach to Fuzzy Control System Design via Fuzzy Lyapunov Functions, IEEE Transactions on Fuzzy Systems, vol.15, issue.3, pp.333-341, 2007. ,
DOI : 10.1109/TFUZZ.2006.880005
Multi-loop decentralized PID control based on covariance control criteria: An LMI approach, ISA Transactions, vol.43, issue.1, pp.49-59, 2004. ,
DOI : 10.1016/S0019-0578(07)60019-6
Robust PID controller design via LMI approach, Journal of Process Control, vol.12, issue.1, pp.3-13, 2003. ,
DOI : 10.1016/S0959-1524(00)00057-3
A quasi-LMI approach to computing stabilizing parameter ranges of multi-loop PID controllers, Journal of Process Control, vol.17, issue.1, pp.59-72, 2007. ,
DOI : 10.1016/j.jprocont.2006.08.006
Stability of a class of switched descriptor systems, 2013 American Control Conference, 2013. ,
DOI : 10.1109/ACC.2013.6579813
Decentralized Static Output Feedback control of interconnected fuzzy descriptors, 2010 IEEE International Symposium on Intelligent Control, 2010. ,
DOI : 10.1109/ISIC.2010.5612895
