Design of a Robust Tracking PD Controller for a Class of Switched Linear Systems with External Disturbances
This paper concerns the design of a robust output feedback tracking controller for a class of Switched Linear Systems (SLS) subject to external disturbances. The proposed synthesis approach, based on a descriptor redundancy formulation, allows to avoid of the crossing terms appearance between the switched Proportional-Derivative (PD) controller's and the switched system's matrices. Using the multiple Lyapunov functional methods, a robust H¥ output feedback tracking performance has been formulated in terms of set of Linear Matrix Inequality (LMI). The effectiveness of the proposed synthesis procedure has been illustrated by a numerical example
