Bounds for minimum feedback vertex sets in distance graphs and circulant graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2008
For a set D ⊂ Zn, the distance graph Pn(D) has Zn as its vertex set and the edges are between vertices i and j with |i − j| ∈ D. The circulant graph Cn(D) is defined analogously by considering operations modulo n. The minimum feedback vertex set problem consists in finding the smallest number of vertices to be removed in order to cut all cycles in the graph. This paper studies the minimum feedback vertex set problem for some families of distance graphs and circulant graphs depending on the value of D.
494-3180-1-PB.pdf (194.16 Ko) Télécharger le fichier
hal-00972307 , version 1 (03-04-2014)
Hamamache Kheddouci, Olivier Togni. Bounds for minimum feedback vertex sets in distance graphs and circulant graphs. Discrete Mathematics and Theoretical Computer Science, 2008, Vol. 10 no. 1 (1), pp.57--70. ⟨10.46298/dmtcs.417⟩. ⟨hal-00972307⟩
227 Consultations
1481 Téléchargements
