applied to the s-set S \ {x s } ? {x j } yields This means that the subgraphs H 1 , x m })] are disjoint, H 1 consisting of the union of s ? 1 disjoint subgraphs K (1,(n?t)/s) Notice that |N G c (x)?N G c (x ? )| ? 1 for every two distinct x, x ? ? {x s , . . . , x m }. Otherwise the set S ? = (S \ {x s?1 , x s }) ? {x, x ? } satisfies (s ? 2)(n ? t)/s + 2((n ? t)/s + 1) ? 2 = n ? t, contradicting again Remark 3.1. Observe also that every cycle of H 2 , if any, has length at least 2(s + 1), because if C is such a cycle of length 2l with 2 ? l ? s, then the s-subset S ? of X consisting of l vertices of C and any s ? l vertices in V (H 1 ) ? X ? {x 1 , . . . , x s?1 } satisfies |N G c (S ? )| = (s ? l)(n ? t)/s + l(n ? t)/s = n ? t, against Remark 3.1. As a consequence, H 2 is either acyclic, or each of its cycles has length at least 2(s + 1) This finishes the proof, ) = ? such that Z(m, n; s, t) is guaranteed to be nonempty (see our comment after Lemma 3.3 and the hypotheses of the theorem) ,
If we denote by r T Y , r T Z and r Y Z the number of edges of the subgraphs G c Let us denote by Y ? and Z ? , respectively, the subsets of Y and Z whose vertices have degree t + n in G. It is clear that, Proof: Assume that e(G) ? n 2 + 2nt ? ,
Extremal Graph Theory, 1978. ,
DOI : 10.1201/b16132-57
Teilweise Lösung eines verallgemeinerten Problems von Zarankiewicz, Anna. Soc. Polon. Math, vol.3, pp.165-168, 1956. ,
New Asymptotics for Bipartite Tur??n Numbers, Journal of Combinatorial Theory, Series A, vol.75, issue.1, pp.141-144, 1996. ,
DOI : 10.1006/jcta.1996.0067
Contributions to the problem of Zarankiewicz, Journal of Statistical Planning and Inference, vol.95, issue.1-2, pp.197-208, 2001. ,
DOI : 10.1016/S0378-3758(00)00288-3
Threshold functions for the bipartite Turán property, Electron, J. Combin, vol.4, p.18, 1997. ,
On the half???half case of the Zarankiewicz problem, Discrete Mathematics, vol.249, issue.1-3, pp.95-104, 2002. ,
DOI : 10.1016/S0012-365X(01)00237-0
(0,1)-Matrices with No Half???Half Submatrix of Ones, European Journal of Combinatorics, vol.18, issue.7, pp.751-761, 1997. ,
DOI : 10.1006/eujc.1996.0133
A problem of Zarankiewicz in: " Theory of Graphs, pp.139-142, 1967. ,
A problem of Zarankiewicz in: " Theory of Graphs, pp.119-150, 1968. ,
A many-facetted problem of zarankiewicz, Lecture Notes in Maths, vol.13, issue.2, pp.129-148, 1969. ,
DOI : 10.1002/sapm1933121321
A problem of Zarankiewicz in: " Recent progress in Combinatorics, pp.237-243, 1969. ,
Sur unprobì eme concernant un reseaù a 36 points, Ann. Pol. Math, vol.24, pp.173-174, 1951. ,
Problems in the Theory of Numbers, p.16, 1964. ,
Problem P 101, Colloq. Math, vol.2, p.301, 1951. ,
