A Local Approach for Negative Emotion Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recognizing human facial expression and emotion by computer is an interesting and challenging problem. In this paper, we propose a method for recognizing negative emotions through an appropriate representation of facial features from relevant face regions displayed in video streams and still images. A measure that is sensitive to facial movements is used in predefined regions of interest to detect the negative emotions. The experimentation has been performed on a standard dataset and live video streams and has showed promising results.
A Local Approach for Negative Emotion Detection.pdf (372.62 Ko) Télécharger le fichier
hal-00973503 , version 1 (29-09-2018)
  • HAL Id : hal-00973503 , version 1
Adel Lablack, Taner Danisman, Ioan Marius Bilasco, Chaabane Djeraba. A Local Approach for Negative Emotion Detection. International Conference on Pattern Recognition, Aug 2014, Stockholm, Sweden. pp.417-420. ⟨hal-00973503⟩
178 Consultations
167 Téléchargements
