Long time behaviour of an exponential integrator for a Vlasov-Poisson system with strong magnetic field
Abstract : With the aim of solving in a four dimensional phase space a multi-scale Vlasov-Poisson system, we propose in a Particle-In-Cell framework a robust time-stepping method that works uniformly when the small parameter vanishes. As an exponential integrator, the scheme is able to use large time steps with respect to the typical size of the solution's fast oscillations. In addition, we show numerically that the method has accurate long time behaviour and that it is asymptotic preserving with respect to the limiting Guiding Center system.
Liste complète des métadonnées
Cited literature [22 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-00974028
Contributor : S. A. Hirstoaga <>
Submitted on : Tuesday, August 18, 2015 - 11:33:18 AM
Last modification on : Friday, April 12, 2019 - 8:08:03 AM
Document(s) archivé(s) le : Thursday, November 19, 2015 - 10:53:41 AM
File
paper3.pdf
Identifiers
Citation
Emmanuel Frenod, Sever Adrian Hirstoaga, Mathieu Lutz, Eric Sonnendrücker. Long time behaviour of an exponential integrator for a Vlasov-Poisson system with strong magnetic field. Communications in Computational Physics, Global Science Press, 2015, 18 (2), pp.263--296. ⟨10.4208/cicp.070214.160115a⟩. ⟨hal-00974028v2⟩
Share
Metrics
Record views
695
Files downloads
295
