Long time behaviour of an exponential integrator for a Vlasov-Poisson system with strong magnetic field
Abstract : With the aim of solving in a four dimensional phase space a multi-scale Vlasov-Poisson system, we propose in a Particle-In-Cell framework a robust time-stepping method that works uniformly when the small parameter vanishes. As an exponential integrator, the scheme is able to use large time steps with respect to the typical size of the solution's fast oscillations. In addition, we show numerically that the method has accurate long time behaviour and that it is asymptotic preserving with respect to the limiting Guiding Center system.
Complete list of metadatas
https://hal.archives-ouvertes.fr/hal-00974028
Contributor : Sever Hirstoaga <>
Submitted on : Friday, April 4, 2014 - 9:47:12 PM
Last modification on : Friday, April 12, 2019 - 8:08:03 AM
Long-term archiving on : Friday, July 4, 2014 - 2:15:25 PM
File
paper2.pdf
Identifiers
  • HAL Id : hal-00974028, version 1
Citation
Emmanuel Frenod, Sever Adrian Hirstoaga, Mathieu Lutz, Eric Sonnendrücker. Long time behaviour of an exponential integrator for a Vlasov-Poisson system with strong magnetic field. 2014. ⟨hal-00974028v1⟩
Share
Metrics
Record views
314
Files downloads
82
