Estimating the eddy-current modelling error - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2008
The eddy-current model is an approximation of the full Maxwell equations. We will give estimates for the modeling error and show how the constants in the estimates are influenced by the geometry of the problem. Additionally, we analyze the asymptotic behavior of the modeling error when the angular frequency tends to zero. The theoretical results are complemented by numerical examples using high order finite elements. These demonstrate that the estimates are sharp. Hence, this work delivers a mathematical basis for assessing the scope of the eddy-current model.
Fichier non déposé
hal-00974795 , version 1 (07-04-2014)
Kersten Schmidt, Oliver Sterz, Ralf Hiptmair. Estimating the eddy-current modelling error. IEEE Transactions on Magnetics, 2008, 44 (6), pp.686-689. ⟨10.1109/TMAG.2008.915834⟩. ⟨hal-00974795⟩
529 Consultations
0 Téléchargements
