Seamless Adaptivity of Elastic Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new adaptive model for viscoelastic solids is presented. Unlike previous approaches, it allows seamless transitions, and simplifications in deformed states. The deformation field is generated by a set of physically animated frames. Starting from a fine set of frames and mechanical energy integration points, the model can be coarsened by attaching frames to others, and merging integration points. Since frames can be attached in arbitrary relative positions, simplifications can occur seamlessly in deformed states, without returning to the original shape, which can be recovered later after refinement. We propose a new class of velocity-based simplification criterion based on relative velocities. Integration points can be merged to reduce the computation time even more, and we show how to maintain constant elastic forces through the levels of detail. This meshless adaptivity allows significant improvements of computation time.
SeamlessAdaptivity_GI2014.pdf (1.32 Mo) Télécharger le fichier
SeamlessAdaptivity_GI2014.mp4 (14.72 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-00975220 , version 1 (08-04-2014)
hal-00975220 , version 2 (08-04-2014)
hal-00975220 , version 3 (28-05-2014)
  • HAL Id : hal-00975220 , version 3
Maxime Tournier, Matthieu Nesme, François Faure, Benjamin Gilles. Seamless Adaptivity of Elastic Models. Graphics Interface, May 2014, Montréal, Canada. pp.17-24. ⟨hal-00975220v3⟩
1063 Consultations
563 Téléchargements
