Solving POMDPs using quadratically constrained linear programs, Proceedings of the fifth international joint conference on Autonomous agents and multiagent systems , AAMAS '06, pp.2418-2424, 2007. ,
DOI : 10.1145/1160633.1160694
URL : http://anytime.cs.umass.edu/aimath06/proceedings/P56.pdf
Incremental policy generation for finitehorizon DEC-POMDPs, Proceedings of the Nineteenth International Conference on Automated Planning and Scheduling, 2009. ,
An investigation into mathematical programming for finite horizon decentralized POMDPs, Journal of Artificial Intelligence Research, vol.37, pp.329-396, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00424394
An approximate algorithm for solving oracular POMDPs, 2008 IEEE International Conference on Robotics and Automation, pp.3346-3352, 2008. ,
DOI : 10.1109/ROBOT.2008.4543721
Optimal control of Markov processes with incomplete state information, Journal of Mathematical Analysis and Applications, vol.10, issue.1, pp.174-205, 1965. ,
DOI : 10.1016/0022-247X(65)90154-X
Learning to act using real-time dynamic programming, Artificial Intelligence, vol.72, issue.1-2, pp.81-138, 1995. ,
DOI : 10.1016/0004-3702(94)00011-O
Solving transition independent decentralized Markov decision processes, Journal of Artificial Intelligence Research, vol.22, pp.423-455, 2004. ,
DOI : 10.1145/860575.860583
URL : http://anytime.cs.umass.edu/shlomo/papers/aamas03a.pdf
Dynamic Programming, 1957. ,
The Complexity of Decentralized Control of Markov Decision Processes, Mathematics of Operations Research, vol.27, issue.4, 2002. ,
DOI : 10.1287/moor.27.4.819.297
Semiring-based constraint satisfaction and optimization, Journal of the ACM, vol.44, issue.2, pp.201-236, 1997. ,
DOI : 10.1145/256303.256306
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.4.3513
Exact dynamic programming for decentralized POMDPs with lossless policy compression, Proceedings of the Eighteenth International Conference on Automated Planning and Scheduling, pp.20-27, 2008. ,
Collective decision under partial observability -a dynamic local interaction model, IJCCI (ECTA-FCTA), pp.146-155, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00969318
Soft arc consistency revisited, Artificial Intelligence, vol.174, issue.78, pp.449-478, 2010. ,
The linear programming approach to approximate dynamic programming, Operations Research, vol.51, issue.6, pp.850-865, 2003. ,
Existential arc consistency: Getting closer to full arc consistency in weighted csps, Proceedings of the Nineteenth International Joint Conference on Artificial Intelligence, pp.84-89, 2005. ,
Bucket elimination: a unifying framework for processing hard and soft constraints, ACM Computing Surveys, vol.28, issue.4es, pp.51-55, 1997. ,
DOI : 10.1145/242224.242302
Bucket elimination: A unifying framework for reasoning, Artificial Intelligence, vol.113, issue.1-2, pp.41-85, 1999. ,
DOI : 10.1016/S0004-3702(99)00059-4
Constraint Optimization, Constraint Processing, pp.363-397, 2003. ,
DOI : 10.1016/B978-155860890-0/50014-1
Mini-buckets, Journal of the ACM, vol.50, issue.2, pp.107-153, 2003. ,
DOI : 10.1145/636865.636866
Abdel-Illah Mouaddib, and Brahim Chaib-draa. Point-based incremental pruning heuristic for solving finite-horizon DEC-POMDPs, Proceedings of the Eighth International Conference on Autonomous Agents and Multiagent Systems, pp.569-576, 2009. ,
Brahim Chaib-draa, and Abdel-Illah Mouaddib. Topological order planner for POMDPs, Proceedings of the Twenty-Second International Joint Conference on Artificial Intelligence, pp.1684-1689, 2009. ,
Scaling up decentralized MDPs through heuristic search, Proceedings of the Twenty-Eighth Conference on Uncertainty in Artificial Intelligence, pp.217-226, 2012. ,
Arnaud Doniec, and François Charpillet Producing efficient error-bounded solutions for transition independent decentralized MDPs, Proceedings of the Twelfth International Conference on Autonomous Agents and Multiagent Systems, 2013. ,
Exploiting separability in multi-agent planning with continuous-state mdps, Proceedings of the Thirteenth International Conference on Autonomous Agents and Multiagent Systems, 2014. ,
Decentralized control of a multiaccess broadcast network, 1981 20th IEEE Conference on Decision and Control including the Symposium on Adaptive Processes, pp.390-391, 1981. ,
DOI : 10.1109/CDC.1981.269554
A heuristic search algorithm that finds solutions with loops, Artificial Intelligence, vol.129, issue.12, pp.35-62, 2001. ,
Dynamic programming for partially observable stochastic games, Proceedings of the Nineteenth National Conference on Artificial Intelligence, pp.709-715, 2004. ,
A formal basis for the heuristic determination of minimum cost paths, IEEE Trans. Systems Science and Cybernetics, vol.4, issue.2, pp.100-107, 1968. ,
Value-function approximations for partially observable Markov decision processes, Journal of Artificial Intelligence Research, vol.13, pp.33-94, 2000. ,
DCOPs meet the real world: Exploring unknown reward matrices with applications to mobile sensor networks, Proceedings of the Twenty-Second International Joint Conference on Artificial Intelligence, pp.181-186, 2009. ,
Planning and acting in partially observable stochastic domains, Artificial Intelligence, vol.101, issue.1-2, pp.99-134, 1998. ,
DOI : 10.1016/S0004-3702(98)00023-X
Real-time heuristic search, Artificial Intelligence, vol.42, issue.2-3, pp.189-211, 1990. ,
DOI : 10.1016/0004-3702(90)90054-4
Task Modelling in Collective Robotics, Autonomous Robots, vol.4, issue.1, pp.53-72, 1997. ,
DOI : 10.1007/978-1-4757-6451-2_3
Constraint-based dynamic programming for decentralized POMDPs with structured interactions, Proceedings of the Eighth International Conference on Autonomous Agents and Multiagent Systems, pp.561-568, 2009. ,
Point-based backup for decentralized POMDPs: complexity and new algorithms, Proceedings of the Ninth International Conference on Autonomous Agents and Multiagent Systems, pp.1315-1322, 2010. ,
Computationally Feasible Bounds for Partially Observed Markov Decision Processes, Operations Research, vol.39, issue.1, 1991. ,
DOI : 10.1287/opre.39.1.162
Point based value iteration with optimal belief compression for Dec-POMDPs, Advances in Neural Information Processing Systems 26, pp.100-108, 2013. ,
On the undecidability of probabilistic planning and related stochastic optimization problems, Artificial Intelligence, vol.147, issue.1-2, pp.5-34, 2003. ,
DOI : 10.1016/S0004-3702(02)00378-8
Decentralized MDPs with sparse interactions, Artificial Intelligence, vol.175, issue.11, pp.1757-1789, 2011. ,
Taming decentralized POMDPs: Towards efficient policy computation for multiagent settings, Proceedings of the Eighteenth International Joint Conference on Artificial Intelligence, pp.705-711, 2003. ,
Networked distributed POMDPs: A synthesis of distributed constraint optimization and POMDPs, Proceedings of the Twentieth National Conference on Artificial Intelligence, pp.133-139, 2005. ,
Sufficient plan-time statistics for decentralized POMDPs, Proceedings of the Twenty-Fourth International Joint Conference on Artificial Intelligence, 2013. ,
Tree-Based Solution Methods for Multiagent POMDPs with Delayed Communication, Proceedings of the Twenty-Sixth AAAI Conference on Artificial Intelligence, 2012. ,
Optimal and approximate Q-value functions for decentralized POMDPs, Journal of Artificial Intelligence Research, vol.32, pp.289-353, 2008. ,
Lossless clustering of histories in decentralized POMDPs, Proceedings of the Eighth International Conference on Autonomous Agents and Multiagent Systems, pp.577-584, 2009. ,
Incremental clustering and expansion for faster optimal planning in Dec-POMDPs, Journal of Artificial Intelligence Research, vol.46, pp.449-509, 2013. ,
Decentralized control of a multiple access broadcast channel: Performance bounds, Proc. of the 35th IEEE Conference on Decision and Control, pp.293-298, 1996. ,
Task allocation learning in a multiagent environment: Application to the RoboCupRescue simulation, Multiagent and Grid Systems, vol.6, issue.4, pp.293-314, 2010. ,
DOI : 10.3233/MGS-2010-0153
Some Recent Results in Heuristic Search Theory, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.6, issue.1, pp.1-13, 1984. ,
DOI : 10.1109/TPAMI.1984.4767470
Anytime point-based approximations for large POMDPs, Journal of Artificial Intelligence Research, vol.27, pp.335-380, 2006. ,
Approximate Dynamic Programming: Solving the Curses of Dimensionality (Wiley Series in Probability and Statistics), 2007. ,
Markov Decision Processes, Discrete Stochastic Dynamic Programming, 1994. ,
Valued constraint satisfaction problems: Hard and easy problems, Proceedings of the Fourteenth International Joint Conference on Artificial Intelligence, pp.631-639, 1995. ,
A survey of point-based POMDP solvers, Autonomous Agents and Multi-Agent Systems, vol.17, issue.2, pp.1-51, 2013. ,
DOI : 10.1007/s10458-012-9200-2
Monte-carlo planning in large POMDPs, Advances in Neural Information Processing Systems 23, pp.2164-2172, 2010. ,
The optimal control of partially observable Markov decision processes over a finite horizon, Operations Research, vol.21, issue.5, pp.1071-1088, 1973. ,
Probabilistic Planning for Robotic Exploration The Robotics Institute, 2007. ,
Heuristic search value iteration for POMDPs, Proceedings of the Twentieth Conference on Uncertainty in Artificial Intelligence, pp.520-527, 2004. ,
Focused real-time dynamic programming for mdps: Squeezing more out of a heuristic, Proceedings of the Twenty-First AAAI Conference on Artificial Intelligence, pp.1227-1232, 2006. ,
Introduction to Reinforcement Learning, 1998. ,
Distributed Anonymous Mobile Robots: Formation of Geometric Patterns, SIAM Journal on Computing, vol.28, issue.4, pp.1347-1363, 1999. ,
DOI : 10.1137/S009753979628292X
MAA*: A heuristic search algorithm for solving decentralized POMDPs, Proceedings of the Twenty-First Conference on Uncertainty in Artificial Intelligence, pp.568-576, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00000204
Feature-based methods for large scale dynamic programming, Machine Learning, pp.59-94, 1996. ,
Contributions to the Theory of Statistical Estimation and Testing Hypotheses, The Annals of Mathematical Statistics, vol.10, issue.4, pp.299-326, 1939. ,
DOI : 10.1214/aoms/1177732144
TCP ex Machina: Computer-Generated Congestion Control, SIGCOMM, 2013. ,
Speeding up the convergence of value iteration in partially observable Markov decision processes, Journal of Artificial Intelligence Research, vol.14, pp.29-51, 2001. ,
Decisiontheoretic control of planetary rovers, Revised Papers from the International Seminar on Advances in Plan-Based Control of Robotic Agents, pp.270-289, 2002. ,
