The fundamental axioms of structural health monitoring, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.463, issue.2082, pp.4631639-1664, 2007. ,
DOI : 10.1098/rspa.2007.1834
Vibrational based inspection of civil engineering structures, 1993. ,
Vibration-based structural damage identification, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.359, issue.1778, pp.359-131, 1778. ,
DOI : 10.1098/rsta.2000.0717
Vibration Based Condition Monitoring: A Review, Structural Health Monitoring, vol.3, issue.4, pp.355-377, 2004. ,
DOI : 10.1177/1475921704047500
Vibration-based Damage Identification Methods: A Review and Comparative Study, Structural Health Monitoring, vol.10, issue.1, pp.83-111, 2011. ,
DOI : 10.1177/1475921710365419
DAMAGE DETECTION OF THE Z24 BRIDGE USING CONTROL CHARTS, Mechanical Systems and Signal Processing, pp.163-170, 2003. ,
DOI : 10.1006/mssp.2002.1555
Dynamic monitoring of a long span arch bridge, Engineering Structures, vol.30, issue.11, pp.3034-3044, 2008. ,
DOI : 10.1016/j.engstruct.2008.04.020
Monitoring historical masonry structures with operational modal analysis: Two case studies, Mechanical Systems and Signal Processing, vol.24, issue.5, pp.1291-1305, 2010. ,
DOI : 10.1016/j.ymssp.2010.01.011
Robust output-only modal identification and monitoring of buildings in the presence of dynamic interactions for rapid post-earthquake emergency management. Engineering Structures, pp.436-446, 2012. ,
Vibration based structural health monitoring of an arch bridge: From automated OMA to damage detection, Mechanical Systems and Signal Processing, vol.28, pp.212-228, 2012. ,
DOI : 10.1016/j.ymssp.2011.06.011
Structural health monitoring of civil infrastructure, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.11, issue.4, pp.365-589, 1851. ,
DOI : 10.1098/rsta.2006.1925
Single sample modal identification of a non-stationary stochastic process, IEEE Transactions on Automatic Control, issue.1, pp.30-66, 1985. ,
Subspace Identification for Linear Systems: Theory, 1996. ,
DOI : 10.1007/978-1-4613-0465-4
Nonstationary Consistency of Subspace Methods, IEEE Transactions on Automatic Control, vol.52, issue.6, pp.974-984, 2007. ,
DOI : 10.1109/TAC.2007.898970
REFERENCE-BASED STOCHASTIC SUBSPACE IDENTIFICATION FOR OUTPUT-ONLY MODAL ANALYSIS, Mechanical Systems and Signal Processing, pp.855-878, 1999. ,
DOI : 10.1006/mssp.1999.1249
Fast multi-order computation of system matrices in subspace-based system identification, Control Engineering Practice, vol.20, issue.9, pp.882-894, 2012. ,
DOI : 10.1016/j.conengprac.2012.05.005
Uncertainty bounds on modal parameters obtained from stochastic subspace identification, Mechanical Systems and Signal Processing, vol.22, issue.4, pp.948-969, 2008. ,
DOI : 10.1016/j.ymssp.2007.10.009
Efficient multi-order uncertainty computation for stochastic subspace identification, Mechanical Systems and Signal Processing, vol.38, issue.2, pp.346-366, 2013. ,
DOI : 10.1016/j.ymssp.2013.01.012
Uncertainty quantification for modal parameters from stochastic subspace identification on multi-setup measurements, Mechanical Systems and Signal Processing, vol.36, issue.2, pp.562-581, 2013. ,
DOI : 10.1016/j.ymssp.2012.11.011
Subspace-based fault detection algorithms for vibration monitoring, Automatica, vol.36, issue.1, pp.101-109, 2000. ,
DOI : 10.1016/S0005-1098(99)00093-X
Statistical model-based damage detection and localization: subspace-based residuals and damage-to-noise sensitivity ratios, Journal of Sound and Vibration, vol.275, issue.3-5, pp.3-5, 2004. ,
DOI : 10.1016/j.jsv.2003.07.016
URL : https://hal.archives-ouvertes.fr/inria-00071940
Subspace-based damage detection under changes in the ambient excitation statistics, Mechanical Systems and Signal Processing, vol.45, issue.1, pp.207-224, 2014. ,
DOI : 10.1016/j.ymssp.2013.10.023
Robust Fault Detection With Statistical Uncertainty in Identified Parameters, IEEE Transactions on Signal Processing, vol.60, issue.10, pp.60-5064, 2012. ,
DOI : 10.1109/TSP.2012.2208638
Assessment of the condition of prestressed or posttensioned German concrete bridges, Bauingenieur, vol.82, issue.1, pp.14-24, 2007. ,
Non-traditional assessment and maintenance methods for aging concrete structures - technical and non-technical issues, Materials and Corrosion, vol.63, issue.12, pp.63-1147, 2012. ,
DOI : 10.1002/maco.201206725
Fatigue life of concrete bridges under consideration of increasing traffic loads, pp.596-606, 2007. ,
Bridge and Highway -Structure, Rehabilitation and Repair, 2010. ,
COST 345 -Procedures Required for the Assessment of Highway Structures, Final Report, 2004. ,
Br??ckenert??chtigung - eine notwendige Voraussetzung f??r ein zuverl??ssiges Fernstra??ennetz, Bautechnik, vol.61, issue.5, pp.184-192, 2013. ,
DOI : 10.1002/bate.201300013
Fully automated (operational) modal analysis, Mechanical Systems and Signal Processing, vol.29, pp.228-250, 2012. ,
DOI : 10.1016/j.ymssp.2012.01.007
