Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Reports
Particle-based methods for parameter estimation and tracking: Numerical experiments
Johann Fichou 1 François Le Gland 1 Laurent Mevel 1
1 SIGMA2 - Signal, models, algorithms
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Abstract : The purpose of this work is to obtain as much intuition as possible, through numerical experiments in a simple case where exact solutions are explicitly available, about the particle approximation of finite signed measures. A prototypical example of a finite signed measure is the derivative, w.r.t. a parameter of the model, of some probability distributions related with a hidden Markov chain. This includes prior, prediction, filtering probability distributions, etc. Two points of view are considered here, to feel the quality of the approximation, at least in a qualitative manner: (i) how accurate is the particle approximation of the finite signed measure, in view of an histogram representation of the weighted particle system? and (ii) considering the log-likelihood function and the score function, how close is the approximate expression provided by the particle approximation to the exact expression? These two questions seem closely related, however the numerical experiments presented in this work show that one of the two particle approximation schemes fails to satisfy the first criteria (quality of the approximation of the finite signed measure), and that both schemes satisfy the second criteria (quality of the approximation of the statistics).
Document type :
Reports
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-00977630
Contributor : Francois Le Gland Connect in order to contact the contributor
Submitted on : Friday, April 11, 2014 - 2:55:07 PM
Last modification on : Friday, February 4, 2022 - 3:20:13 AM
Long-term archiving on: : Monday, April 10, 2017 - 12:07:59 PM
File
PI-1604.pdf
Identifiers
  • HAL Id : hal-00977630, version 2
Citation
Johann Fichou, François Le Gland, Laurent Mevel. Particle-based methods for parameter estimation and tracking: Numerical experiments. [Research Report] PI 1604, 2004. ⟨hal-00977630v2⟩
Share
Metrics
Record views
258
Files downloads
112
