Foundations of theory of discontinuous systems i. Automation and Remote Control, pp.1066-1079, 1974. ,
Nonpathological Lyapunov functions and discontinuous Carath??odory systems, Automatica, vol.42, issue.3, pp.453-458, 2006. ,
DOI : 10.1016/j.automatica.2005.10.014
Lyapunov Functions and Stability in Control Theory, 2005. ,
Lyapunov Functions, Moscow:Nauka [in Russian], 1970. ,
Variable structure systems nonlinear in the control law, IEEE Transactions on Automatic Control, vol.30, issue.7, pp.681-684, 1985. ,
DOI : 10.1109/TAC.1985.1104025
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Discontinuous control systems : frequencydomain analysis and design, 2009. ,
Generalized Lyapunov and invariant set theorems for nonlinear dynamical systems, Systems & Control Letters, vol.38, issue.4-5, pp.289-295, 1999. ,
DOI : 10.1016/S0167-6911(99)00076-6
Robust Throttle Control of Automotive Engines: Theory and Experiment, Journal of Dynamic Systems, Measurement, and Control, vol.118, issue.1, pp.92-98, 1996. ,
DOI : 10.1115/1.2801156
Qualitative properties of trajectories of control systems: A survey, Journal of Dynamical and Control Systems, vol.20, issue.No. 2, pp.1-48, 1995. ,
DOI : 10.1007/BF02254655
Asymptotic Stability and Smooth Lyapunov Functions, Journal of Differential Equations, vol.149, issue.1, pp.69-114, 1998. ,
DOI : 10.1006/jdeq.1998.3476
Differential Equations with Discontinuous Righthand Sides, 1988. ,
DOI : 10.1007/978-94-015-7793-9
Discontinuous automatic control, 1953. ,
DOI : 10.1515/9781400877218
Stability of Motion, 1967. ,
DOI : 10.1007/978-3-642-50085-5
Input-to-state stability and interconnections of discontinuous dynamical systems, Automatica, vol.44, issue.12, pp.3079-3086, 2008. ,
DOI : 10.1016/j.automatica.2008.04.025
Sliding order and sliding accuracy in sliding mode control, International Journal of Control, vol.51, issue.6, pp.1247-1263, 1993. ,
DOI : 10.1109/TAC.1977.1101661
The general problem of the stability of motion, 1992. ,
Variational Analysis and Generalized Differentiation I: Basic Theory, 2006. ,
DOI : 10.1007/3-540-31247-1
Strict Lyapunov Functions for the Super-Twisting Algorithm, IEEE Transactions on Automatic Control, vol.57, issue.4, pp.1035-1040, 2012. ,
DOI : 10.1109/TAC.2012.2186179
Finite time stability conditions for non-autonomous continuous systems, International Journal of Control, vol.55, issue.5, pp.797-803, 2008. ,
DOI : 10.1080/00207177908922792
URL : https://hal.archives-ouvertes.fr/hal-00177572
Theory of functions of a real variable, 1955. ,
Note on A. Filippov paper, Proceedings of 1st IFAC Congress II. Butterworths, 1961. ,
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
DOI : 10.1137/S0363012903425593
Lyapunov function design for finite-time convergence analysis: ???Twisting??? controller for second-order sliding mode realization, Automatica, vol.45, issue.2, pp.444-448, 2009. ,
DOI : 10.1016/j.automatica.2008.07.013
Reaching Time Estimation for “Super-Twisting” Second Order Sliding Mode Controller via Lyapunov Function Designing, IEEE Transactions on Automatic Control, vol.54, issue.8, pp.1951-1955, 2009. ,
DOI : 10.1109/TAC.2009.2023781
Unified Lyapunov function for a finite-time stability analysis of relay second-order sliding mode control systems, IMA Journal of Mathematical Control and Information, vol.29, issue.4, pp.529-550, 2012. ,
DOI : 10.1093/imamci/dns007
Advanced Mathematical Tools for Automatic Control Engineers, 2008. ,
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.XV, issue.3, pp.273-283, 1966. ,
DOI : 10.1007/BF02844106
Lyapunov stability theory of nonsmooth systems, IEEE Transactions on Automatic Control, vol.39, issue.9, pp.1910-1914, 1994. ,
DOI : 10.1109/9.317122
Relay Control Systems, 1984. ,
Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009. ,
DOI : 10.1080/10241230306724
The inadequacy of the method of characteristic exponents for the study of nonlinear differential equations, Math. Sbornik, issue.83, pp.41431-438, 1957. ,
Sur une extension de la notion d'equation differentiel, Comptes Rendus Acad. Sc, vol.199, pp.545-548, 1934. ,
Lower semicontinuous Lyapunov functions and subdifferential calculus, Proceedings of the 41st IEEE Conference on Decision and Control, 2002., 2002. ,
DOI : 10.1109/CDC.2002.1184589
