Soft variable-structure controls: a survey, Automatica, vol.40, issue.11, pp.1821-1844, 2004. ,
DOI : 10.1016/j.automatica.2004.05.017
Dynamic Programming, 1957. ,
1. The simulation results for h = 0 ,
Optimal nonlinear, but continuous, feedback control of systems with saturating actuators, International Journal of Control, vol.62, issue.5, pp.1209-1216, 1995. ,
DOI : 10.1016/0167-6911(92)90001-9
Dynamic Programming and Suboptimal Control: A Survey from ADP to MPC*, European Journal of Control, vol.11, issue.4-5, pp.310-334, 2005. ,
DOI : 10.3166/ejc.11.310-334
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Time-optimal regulation of a chain of integrators with saturated input and internal variables: an application to trajectory planning, 8th IFAC Symposium on Nonlinear Control Systems, pp.1278-1283, 2010. ,
DOI : 10.3182/20100901-3-IT-2016.00211
Linear Feedback vs. Time Optimal Control. I. The Servo Problem, Industrial & Engineering Chemistry Process Design and Development, vol.15, issue.1, pp.24-33, 1976. ,
DOI : 10.1021/i260057a006
The Robust Maximum Principle: Theory and Applications, 2012. ,
Control of nonlinear dynamical systems: methods and applications, 2008. ,
DOI : 10.1007/978-3-540-70784-4
Introduction to calculus and analysis (, 2000. ,
Higher Order Sliding Mode Controllers With Optimal Reaching, IEEE Transactions on Automatic Control, vol.54, issue.9, pp.2126-2136, 2009. ,
DOI : 10.1109/TAC.2009.2026940
Optimal processes in systems of automatic control. Automation and Remote Control, pp.712-728, 1953. ,
Robust Controllability of Linear Systems ,
A general approach to synthesis problem, Doklady Academii Nauk SSSR, vol.248, pp.1051-1063, 1979. ,
Nonlinear optimal control: approximations via moments and LMI-relaxations, Proceedings of the 44th IEEE Conference on Decision and Control, pp.1648-1653, 2005. ,
DOI : 10.1109/CDC.2005.1582395
Finite-time Stabilization Using Implicit Lyapunov Function Technique, 9th Symposium on Nonlinear Control Systems, pp.140-145, 2013. ,
DOI : 10.3182/20130904-3-FR-2041.00043
URL : https://hal.archives-ouvertes.fr/hal-00844386
Robust nonasymptotic stabilization of linear systems, International Journal of Robust and Nonlinear Control, 2014. ,
The Mathematical Theory of Optimal Processes, 1962. ,
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.XV, issue.3, pp.273-283, 1966. ,
DOI : 10.1007/BF02844106
Control of uncertain systems with bounded inputs. Lecture notes in control and information sciences, 1997. ,
Advanced global optimization algorithms for parameterized LMIs, Proceedings of the 38th IEEE Conference on Decision and Control (Cat. No.99CH36304), 1999. ,
DOI : 10.1109/CDC.1999.832794
Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009. ,
DOI : 10.1080/10241230306724
Control of a chain of integrators subject to actuator saturation and disturbances, International Journal of Robust and Nonlinear Control, vol.13, issue.8, pp.1562-1570, 2012. ,
DOI : 10.1002/rnc.1767
