Oxygen adsorption on the Al9Co2(001) surface: first-principles and STM study
Abstract : Atomic oxygen adsorption on the pure aluminium terminated Al9Co2 (001) surface is studied by first principle calculations coupled with STM measurements. Relative adsorption energy of oxygen atoms have been calculated on different surface sites along with the associated STM images. The local electronic structure of the most favourable adsorption site is described. The preferential adsorption site is identified as a "bridge" type site between the cluster entities exposed at the (001) surface termination. The Al-O bonding between the adsorbate and the substrate presents a covalent character, with s − p hybridization occuring between the states of the adsorbed oxygen atom and the aluminium atoms of the surface. The simulated STM image of the preferential adsorption site is in agreement with experimental observations. This work shows that oxygen adsorption generates important atomic relaxations of the topmost surface layer and that sub-surface cobalt atoms strongly influence the values of the adsorption energies. The calculated Al-O distances are in agreement with those reported in Al2O and Al2O3 oxides and for oxygen adsorption on Al(111).
Type de document :
Article dans une revue
Journal of Physics: Condensed Matter, IOP Publishing, 2013, 25, pp.355003. 〈10.1088/0953-8984/25/35/355003〉
Liste complète des métadonnées
Littérature citée [32 références]  Voir  Masquer  Télécharger
https://hal.archives-ouvertes.fr/hal-00977985
Contributeur : Emilie Gaudry <>
Soumis le : lundi 20 octobre 2014 - 18:08:57
Dernière modification le : lundi 9 avril 2018 - 12:40:09
Document(s) archivé(s) le : mercredi 21 janvier 2015 - 11:25:30
Fichier
Gaudry.pdf
Fichiers produits par l'(les) auteur(s)
Collections
Citation
S. Alarcon Villaseca, L. Serkovic Loli, J. Ledieu, V. Fournée, P. Gille, et al.. Oxygen adsorption on the Al9Co2(001) surface: first-principles and STM study. Journal of Physics: Condensed Matter, IOP Publishing, 2013, 25, pp.355003. 〈10.1088/0953-8984/25/35/355003〉. 〈hal-00977985〉
Métriques
Consultations de la notice
96
Téléchargements de fichiers
110
