Atomistic description of oxide formation on metal surfaces: the example of ruthenium, Chemical Physics Letters, vol.352, issue.5-6, p.311, 2002. ,
DOI : 10.1016/S0009-2614(01)01472-5
Elementary Reaction Steps in Heterogeneous Catalysis, NATO ASI. Series C, Kluwer Academic Pub, 1993. ,
Abstractive dissociation of oxygen over Al(111): A nonadiabatic quantum model, The Journal of Chemical Physics, vol.120, issue.8, p.3931, 2004. ,
DOI : 10.1063/1.1635360
on Al(111), Dissociative sticking of O 2 on Al, p.15452, 1997. ,
DOI : 10.1103/PhysRevB.55.15452
Growth of ultra-thin amorphous Al2O3 films on CoAl(), Surface Science, vol.541, issue.1-3, p.128, 2003. ,
DOI : 10.1016/S0039-6028(03)00891-4
High temperature oxidation of CoAl(100), Surface Science, vol.577, issue.2-3, p.139, 2005. ,
DOI : 10.1016/j.susc.2004.12.028
Growth of thin, crystalline oxide, nitride and oxynitride films on metal and metal alloy surfaces, Surface Science Reports, vol.38, issue.6-8, p.199, 2000. ,
DOI : 10.1016/S0167-5729(99)00013-8
Combined EELS STM study of the adsorption of nitric oxide and the formation of GaO x N y on CoGa(001), Surf. Sci, vol.91, p.427, 1999. ,
Oxygen adsorption on Al(111): low transient mobility, Surface Science, vol.478, issue.3, p.355, 2001. ,
DOI : 10.1016/S0039-6028(01)00967-0
dissociation at Al(111): First-principles fewest-switches study, Physical Review B, vol.81, issue.3, p.35410, 2010. ,
DOI : 10.1103/PhysRevB.81.035410
URL : http://arxiv.org/abs/0910.0336
Surface migration of ??????hot?????? adatoms in the course of dissociative chemisorption of oxygen on Al(111), Physical Review Letters, vol.68, issue.5, p.624, 1992. ,
DOI : 10.1103/PhysRevLett.68.624
Interaction of oxygen with Al(111) studied by scanning tunneling microscopy, The Journal of Chemical Physics, vol.99, issue.3, p.2128, 1993. ,
DOI : 10.1063/1.465278
Motion of ??????hot?????? oxygen adatoms on corrugated metal surfaces, The Journal of Chemical Physics, vol.105, issue.1, p.326, 1996. ,
DOI : 10.1063/1.471877
Adiabatic potential-energy surfaces for oxygen on Al(111), Physical Review B, vol.65, issue.7, p.75416, 2002. ,
DOI : 10.1103/PhysRevB.65.075416
Challenges and errors: interpreting high resolution images in scanning tunneling microscopy, Progress in Surface Science, vol.71, issue.5-8, p.147, 2003. ,
DOI : 10.1016/S0079-6816(03)00005-4
STM-theory: Image potential, chemistry and surface relaxation, Progress in Surface Science, vol.81, issue.10-12, p.403, 2006. ,
DOI : 10.1016/j.progsurf.2006.07.004
Theory and Application for the Scanning Tunneling Microscope, Physical Review Letters, vol.50, issue.25, 1983. ,
DOI : 10.1103/PhysRevLett.50.1998
Theory of the scanning tunneling microscope, Basics of Thermodynamics And Phase Transitions In Complex Intermetallics, p.805, 1985. ,
DOI : 10.1103/PhysRevB.31.805
Structural investigation of the (001) surface of the Al 9 Co 2 complex metallic alloy, J. Phys. Chem. C, vol.115, p.14922, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00974222
Initial oxidation of AlPdMn quasicrystals a study by high-resolution RBS and ERDA. Nuclear Instruments and Methods in, Physics Research B, vol.190, p.646, 2002. ,
Initial oxidation of quasicrystals ??? an investigation by high-resolution RBS and ERDA, Journal of Non-Crystalline Solids, vol.334, issue.335, pp.334-335524, 2004. ,
DOI : 10.1016/j.jnoncrysol.2003.12.035
Microstructure and corrosion performance of Al-32%Co alloys, Corrosion Science, vol.63, p.193, 2012. ,
DOI : 10.1016/j.corsci.2012.06.002
total-energy calculations using a plane-wave basis set, Physical Review B, vol.54, issue.16, p.11169, 1996. ,
DOI : 10.1103/PhysRevB.54.11169
Efficiency of ab-initio total energy calculations for metals and semiconductors using a plane-wave basis set, Computational Materials Science, vol.6, issue.1, p.15, 1996. ,
DOI : 10.1016/0927-0256(96)00008-0
Projector augmented-wave method, Physical Review B, vol.50, issue.24, p.17953, 1994. ,
DOI : 10.1103/PhysRevB.50.17953
From ultrasoft pseudopotentials to the projector augmented-wave method, Physical Review B, vol.59, issue.3, p.1758, 1999. ,
DOI : 10.1103/PhysRevB.59.1758
Generalized Gradient Approximation Made Simple, Physical Review Letters, vol.77, issue.18, p.3865, 1996. ,
DOI : 10.1103/PhysRevLett.77.3865
Generalized Gradient Approximation Made Simple [Phys. Rev. Lett. 77, 3865 (1996)], Physical Review Letters, vol.78, issue.7, p.1396, 1997. ,
DOI : 10.1103/PhysRevLett.78.1396
Chlorine interaction with defects on the Au(111) surface: A first-principles theoretical investigation, The Journal of Chemical Physics, vol.129, issue.10, p.104702, 2008. ,
DOI : 10.1063/1.2975329
Effects of chlorine and oxygen coverage on the structure of the Au(111) surface, The Journal of Chemical Physics, vol.130, issue.8, p.84701, 2009. ,
DOI : 10.1063/1.3077314
First-principles study of surface and subsurface O structures at Al(111), Physical Review B, vol.63, issue.8, p.85405, 2001. ,
DOI : 10.1103/PhysRevB.63.085405
Stability of oxygen adsorption sites and ultrathin aluminum oxide films on al(111) Surface Science [40] A. Benali. ´ Etude ab initio d'alliages AlCu: phénomènes de ségrégation et modification de la réactivité de surface vis-` a-vis de l'oxygène, pp.1-10, 2002. ,
