Structural investigation of the (110) surface of γ-Al4Cu9
Abstract : We present a detailed study of the (110) surface of the γ-Al4Cu9 crystal using both experimental methods and first-principles calculations based on density-functional theory. Our experimental approach, using low-energy electron diffraction, scanning tunneling microscopy (STM) images, and x-ray photoelectron spectroscopy highlights the presence of two types of surface terminations. Combining experimental results and simulations provides many arguments to match the two observed surfaces with the two puckered terminations built from bulk truncation: (i) calculations show that these two puckered terminations present lower surface energies compared to another conceivable flat termination obtained also from bulk truncation, (ii) step height measurements are consistent with calculated interlayer spacings and (iii) simulated STM images are in reasonable agreement with the experimental ones and mirror the experimental voltage dependence.
Type de document :
Article dans une revue
Physical Review B : Condensed matter and materials physics, American Physical Society, 2010, 82, pp.085411. 〈10.1103/PhysRevB.82.085411〉
Liste complète des métadonnées
Littérature citée [1 références]  Voir  Masquer  Télécharger
https://hal.archives-ouvertes.fr/hal-00977987
Contributeur : Emilie Gaudry <>
Soumis le : vendredi 11 avril 2014 - 19:53:01
Dernière modification le : jeudi 11 janvier 2018 - 06:23:09
Document(s) archivé(s) le : vendredi 11 juillet 2014 - 13:10:11
Fichier
PhysRevB.82.085411.pdf
Fichiers éditeurs autorisés sur une archive ouverte
Collections
Citation
Emilie Gaudry, A. Shukla, T. Duguet, J. Ledieu, M.-C. De Weerd, et al.. Structural investigation of the (110) surface of γ-Al4Cu9. Physical Review B : Condensed matter and materials physics, American Physical Society, 2010, 82, pp.085411. 〈10.1103/PhysRevB.82.085411〉. 〈hal-00977987〉
Métriques
Consultations de la notice
93
Téléchargements de fichiers
162
