Structure investigation of the (100) surface of the orthorhombic Al13Co4 crystal
Abstract : We present a detailed study of the (100) surface of the orthorhombic Al13Co4 crystal using both experimental and ab initio computational methods. This complex metallic alloy is an approximant of the decagonal Al-Ni-Co quasicrystalline phase. After sputter-annealing preparation of the surface at 1073 K, the low-energy electron diffraction pattern recorded exhibits a pseudotenfold symmetry with lattice parameters consistent with those of the bulk model. At this stage, scanning tunneling microscopy (STM) measurements reveal two different types of surface terminations. A comparison between these two surface structures and the bulk planes indicate that the terminations correspond either to an incomplete puckered layer (P) or to an incomplete flat layer (F). At 1173 K, the majority of the surface consists of P layer terminations. STM images calculated from our proposed surface model are in good agreement with experimental images. X-ray photoelectron diffraction patterns and single scattering cluster calculations further confirm that the local atomic arrangements present in the bulk model are preserved within the near-surface region.
Type de document :
Article dans une revue
Physical Review B : Condensed matter and materials physics, American Physical Society, 2009, 80, pp.014203. 〈10.1103/PhysRevB.80.014203〉
Liste complète des métadonnées
Littérature citée [3 références]  Voir  Masquer  Télécharger
https://hal.archives-ouvertes.fr/hal-00978014
Contributeur : Emilie Gaudry <>
Soumis le : vendredi 11 avril 2014 - 21:13:10
Dernière modification le : vendredi 24 août 2018 - 15:46:01
Document(s) archivé(s) le : vendredi 11 juillet 2014 - 13:10:43
Fichier
PhysRevB.80.014203.pdf
Fichiers éditeurs autorisés sur une archive ouverte
Collections
Citation
R. Addou, Emilie Gaudry, Th. Deniozou, Marc Heggen, M. Feuerbacher, et al.. Structure investigation of the (100) surface of the orthorhombic Al13Co4 crystal. Physical Review B : Condensed matter and materials physics, American Physical Society, 2009, 80, pp.014203. 〈10.1103/PhysRevB.80.014203〉. 〈hal-00978014〉
Métriques
Consultations de la notice
126
Téléchargements de fichiers
206
