Spin magnetic moments from single atoms to small Cr clusters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue physica status solidi (b) Année : 2005
Morphology studies at the first stages of the growth of Cr/Au(111) are reported and compared to the magnetic properties of the nanostructures. We analyze by Scanning Tunneling Microscopy and Low Energy Electron Diffraction the Cr clusters growth between 200 K and 300 K. In the early stages of the growth the morphology of the clusters shows monoatomic high islands located at the kinks of the herringbone reconstructed Au(111) surface. By X-ray Magnetic Circular Dichroism performed on the Cr L2,3 edges it is shown that the temperature dependent morphology strongly influences the magnetic properties of the Cr clusters. We show that in the sub-monolayer regime Cr clusters are antiferromagnetic and paramagnetic when the size reaches the atomic limit.
hal-00978043 , version 1 (11-04-2014)
Christine Boeglin, Philippe Ohresser, R. Decker, Hervé Bulou, Fabrice Scheurer, et al.. Spin magnetic moments from single atoms to small Cr clusters. physica status solidi (b), 2005, 242 (9), pp.1775-1778. ⟨10.1002/pssb.200461714⟩. ⟨hal-00978043⟩
63 Consultations
0 Téléchargements
