Programming by Feedback - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper advocates a new ML-based programming framework, called Programming by Feedback (PF), which involves a sequence of interactions between the active computer and the user. The latter only provides preference judgments on pairs of solutions supplied by the active computer. The active computer involves one learning and one optimization components; the learning component estimates the user's utility function and accounts for the user's (possibly limited) competence; the optimization component explores the search space and returns the most appropriate candidate solution. A proof of principle of the approach is proposed, showing that PF requires a handful of interactions in order to solve some discrete and continuous benchmark problems.
programming_by_feedback.pdf (258.55 Ko) Télécharger le fichier
hal-00980839 , version 1 (22-04-2014)
  • HAL Id : hal-00980839 , version 1
Riad Akrour, Marc Schoenauer, Michèle Sebag, Jean-Christophe Souplet. Programming by Feedback. International Conference on Machine Learning, Jun 2014, Pékin, China. pp.1503-1511. ⟨hal-00980839⟩
2192 Consultations
796 Téléchargements
