Finite-time Analysis of the Multiarmed Bandit Problem, Machine Learning, vol.47, pp.2-3, 2002. ,
Learning to Act Using Real-Time Dynamic Programming, Artificial Intelligence, vol.72, issue.12, pp.81-138, 1995. ,
Lower bounding klondike solitaire with monte-carlo planning, Proc. ICAPS, 2009. ,
Learning in Real-Time Search : A Unifying Framework, Journal of Artificial Intelligence Research, vol.25, pp.119-157, 2006. ,
Monte-Carlo Tree Search in Production Management Problems, Proceedings of the 18th BeNeLux Conference on Artificial Intelligence, pp.91-98, 2006. ,
Progressive Strategies for Monte-Carlo Tree Search, New Mathematics and Natural Computation, vol.4, issue.3, pp.343-357, 2008. ,
The ReSSAC Autonomous Helicopter : Flying in a Non-Cooperative Uncertain World with embedded Vision and Decision Making, A.H.S Forum, 2007. ,
Speeding up the Convergence of Real-Time Search, Proceedings of the National Conference on Artificial Intelligence, pp.891-897, 2000. ,
Modification of UCT with Patterns in Monte- Carlo Go, 2006. ,
LAO* : A Heuristic Search Algorithm that Finds Solutions with Loops, Artificial Intelligence, vol.129, issue.12, pp.35-62, 2001. ,
A Formal Basis for the Heuristic Determination of Minimum Cost Paths, IEEE Transactions on Systems Science and Cybernetics SSC4, vol.2, pp.100-107, 1968. ,
The FF Planning System : Fast Plan Generation Through Heuristic Search, JAIR, vol.14, issue.1, pp.253-302, 2001. ,
Bandit-based Monte-Carlo Planning, Proc. ECML, pp.282-293, 2006. ,
Monte-carlo exploration for deterministic planning, Proc. IJCAI, 2009. ,
An UCT Approach for Anytime Agent-based Planning, Proc. PAAMS, 2010. ,
The lama planner using landmark counting in heuristic search, Proceedings of the International Conference on Planning and Scheduling, 2008. ,
Learning from Planner Performance, Artificial Intelligence, vol.173, pp.536-561, 2009. ,
Controlling the Learning Process of Real-Time Heuristic Search, Artificial Intelligence, vol.146, issue.1, pp.1-41, 2003. ,
An Admissible Heuristic Search Algorithm, Methodologies for Intelligent Systems, number 689 in LNAI, 1993. ,
