An UCT Approach for Anytime Agent-based Planning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
{In this paper, we introduce a new heuristic search algorithm based on mean values for anytime planning, called MHSP. It consists in associating the principles of UCT, a bandit-based algorithm which gave very good results in computer games, and especially in Computer Go, with heuristic search in order to obtain an anytime planner that provides partial plans before finding a solution plan, and furthermore finding an optimal plan. The algorithm is evaluated in different classical planning problems and compared to some major planning algorithms. Finally, our results highlight the capacity of MHSP to return partial plans which tend to an optimal plan over the time.
paams10.pdf (129.27 Ko) Télécharger le fichier
hal-00981649 , version 1 (22-04-2014)
  • HAL Id : hal-00981649 , version 1
Damien Pellier, Bruno Bouzy, Marc Métivier. An UCT Approach for Anytime Agent-based Planning. International Conference on Practical Applications of Agents and Multi-Agent Systems, Apr 2010, Salamanca, Spain. ⟨hal-00981649⟩
Collections
LIPADE UP-SCIENCES
252 Consultations
485 Téléchargements
