HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Synthesis, structural and magnetic studies of the of the CuCr1-xCoxO2 delafossite oxide
Abstract : We modulate the spin chirality and the magnetization in CuCrO2, by doping at Cr3 þ sites with magnetic ions of slightly different size. Structure and magnetic properties of delafossite oxide CuCr1ﰄxCoxO2 (0 r x r 0.06) have been investigated. With the substitution of magnetic Co3 þ for Cr3 þ (S 1⁄4 3/2), the antiferromagnetic (AF) transition becomes broader and the transition temperature increases. However, at low temperature, the magnetic data for CuCr1ﰄxCoxO2 shows evidence for weak ferromagnetism. Comparing the substitution effect of Co3 þ to those of other magnetic metal transition, magnetization around the AF transition does not seem to correlate with randomness and lattice parameter.
Complete list of metadata
https://hal.inria.fr/hal-00984212
Contributor : Pierre Strobel Connect in order to contact the contributor
Submitted on : Monday, April 28, 2014 - 8:36:02 AM
Last modification on : Monday, January 31, 2022 - 11:40:02 AM
Identifiers
Collections
CNRS | UGA | NEEL
Citation
T. Elkhouni, M. Amami, Claire Colin, Pierre Strobel, A. Ben Salah. Synthesis, structural and magnetic studies of the of the CuCr1-xCoxO2 delafossite oxide. Journal of Magnetism and Magnetic Materials, Elsevier, 2013, 330, pp.101-105. ⟨10.1016/j.jmmm.2012.10.037⟩. ⟨hal-00984212⟩
Share
Metrics
Record views
49
