Dynamical model identification of population of oysters for water quality monitoring
The measurements of valve activity in a population of bivalves under natural environmental conditions (16 oysters in the Bay of Arcachon, France) are used for a physiological model identification. A nonlinear auto-regressive exogenous (NARX) model is designed and tested. The model takes into account the influence of environmental conditions using measurements of the sunlight intensity, the moonlight and tide levels. A possible influence of the internal circadian/circatidal clocks is also analyzed. Through this application, it is demonstrated that the developed dynamical model can be used for estimation of the normal physiological rhythms of permanently immersed oysters and considered for detection of perturbations of these rhythms due to changes in the water quality, i.e. for ecological monitoring.
Automatique
