State estimation for linear switched systems with unstable invariant zeros and unknown inputs, 2012 IEEE 51st IEEE Conference on Decision and Control (CDC), pp.5499-5504, 2012. ,
DOI : 10.1109/CDC.2012.6426455
Switching in Systems and Control. Systems and Control: Foundations and Applications, 2003. ,
Dynamical properties of hybrid automata, IEEE Transactions on Automatic Control, vol.48, issue.1, pp.2-17, 2003. ,
DOI : 10.1109/TAC.2002.806650
Stability and Stabilizability of Switched Linear Systems: A Survey of Recent Results, IEEE Transactions on Automatic Control, vol.54, issue.2, pp.308-322, 2009. ,
DOI : 10.1109/TAC.2008.2012009
Design of observers for switched discretetime linear systems, Proceedings of the 2003 American Control Conference, pp.2785-2790, 2003. ,
Finite-time converging jump observer for switched linear systems with unknown inputs, Nonlinear Analysis: Hybrid Systems, vol.5, issue.2, pp.174-188, 2011. ,
Simultaneous state and input estimation of hybrid systems with unknown inputs, Automatica, vol.42, issue.5, pp.1755-762, 2006. ,
DOI : 10.1016/j.automatica.2005.12.014
Switched observers for switched linear systems with unknown inputs, IEEE Transactions on Automatic Control, vol.56, issue.3, pp.681-686, 2011. ,
State estimation and sliding-mode control of markovian jump singular systems, IEEE Transactions on Automatic Control, vol.55, issue.5, pp.1213-1219, 2010. ,
Invertibility of switched linear systems, Automatica, vol.44, issue.4, pp.949-958, 2008. ,
DOI : 10.1016/j.automatica.2007.08.015
Robust finite time observer design for multicellular converters, International Journal of Systems Science, vol.49, issue.11, pp.773-791, 2011. ,
DOI : 10.1016/j.automatica.2008.05.015
URL : https://hal.archives-ouvertes.fr/hal-00643947
Hybrid adaptive observers for locally Lipschitz systems with application to mechanical oscillators, 2009 IEEE International Conference on Control Applications, pp.619-624, 2009. ,
DOI : 10.1109/CCA.2009.5281023
State Observation for Nonlinear Switched Systems Using Nonhomogeneous High-Order Sliding Mode Observers, Asian Journal of Control, vol.56, issue.2, pp.911-923, 2012. ,
DOI : 10.1002/asjc.516
Nonlinear observer for autonomous switching systems with jumps, Nonlinear Analysis: Hybrid Systems, vol.1, issue.4, pp.537-547, 2007. ,
DOI : 10.1016/j.nahs.2006.01.001
State observer and observability conditions for a class of hybrid continuousdiscrete dynamic system, Proc. 46th IEEE Conf. Decision Control, pp.708-713, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00177803
On the observability of nonlinear and switched systems Emergent Problems in Nonlinear Systems and Control, Lecture Notes in Control and Information Science, pp.199-216, 2009. ,
Robust reconstruction of the discrete state for a class of nonlinear uncertain switched systems, Nonlinear Analysis: Hybrid Systems, vol.5, issue.2, pp.220-232, 2011. ,
Continuous and Discrete State Estimation in Linear Switched Systems by Sliding Mode Observers with Residuals' Projection, Proceedings of the 4th IFAC Conference on Analysis and Design of Hybrid Systems, pp.265-270, 2012. ,
DOI : 10.3182/20120606-3-NL-3011.00092
URL : https://hal.archives-ouvertes.fr/hal-00731063
High-order sliding mode observers for nonlinear autonomous switched systems with unknown inputs, Journal of the Franklin Institute, vol.349, issue.10, pp.2975-3002, 2012. ,
DOI : 10.1016/j.jfranklin.2012.07.003
A Survey of Fault Detection, Isolation, and Reconfiguration Methods, IEEE Transactions on Control Systems Technology, vol.18, issue.3, pp.636-653, 2010. ,
DOI : 10.1109/TCST.2009.2026285
A redundancy-based strategy for safety management in a modern civil aircraft, Control Engineering Practice, vol.8, issue.5, pp.545-554, 2000. ,
DOI : 10.1016/S0967-0661(99)00172-0
URL : https://hal.archives-ouvertes.fr/hal-00324058
Design and analysis of robust residual generators for systems under feedback control, Automatica, vol.41, issue.2, pp.251-264, 2005. ,
DOI : 10.1016/j.automatica.2004.09.013
URL : https://hal.archives-ouvertes.fr/hal-00164870
DESIGN OF ROBUST FAULT DETECTION FILTERS FOR MULTIVARIABLE FEEDBACK SYSTEMS, International Journal of Modelling and Simulation, vol.26, issue.1, pp.17-26, 2006. ,
DOI : 10.2316/Journal.205.2006.1.205-4101
URL : https://hal.archives-ouvertes.fr/hal-00164862
Survey of robust residual generation and evaluation methods in observer-based fault detection systems, Journal of Process Control, vol.7, issue.6, pp.403-424, 1997. ,
DOI : 10.1016/S0959-1524(97)00016-4
Robust model-based fault diagnosis for dynamic systems, 1999. ,
DOI : 10.1007/978-1-4615-5149-2
Diagnosis and fault tolerant control, 2003. ,
Advanced model-based FDIR techniques for aerospace systems: Today challenges and opportunities, Progress in Aerospace Sciences, vol.53, pp.18-29, 2012. ,
DOI : 10.1016/j.paerosci.2012.02.004
URL : https://hal.archives-ouvertes.fr/hal-00673990
Sliding mode observers for fault detection and isolation, Automatica, vol.36, issue.4, pp.541-553, 2000. ,
DOI : 10.1016/S0005-1098(99)00177-6
Nonlinear robust fault reconstruction and estimation using sliding mode observer, Automatica, vol.43, issue.9, pp.1605-1614, 2007. ,
Observation of linear systems with unknown inputs via high-order sliding-modes, International Journal of Systems Science, vol.38, issue.10, pp.773-791, 2007. ,
DOI : 10.1080/00207179308934441
Sliding mode estimation schemes for incipient sensor faults, Automatica, vol.45, issue.7, pp.1679-1865, 2009. ,
DOI : 10.1016/j.automatica.2009.02.031
Sliding mode methods for fault detection and fault tolerant control, Conference on Control and Fault-Tolerant Systems, pp.106-117, 2010. ,
Fault detection and isolation for hybrid systems using structured parity residuals, Proceedings of the 5th Asian Control Conference, 2004. ,
Monitoring and Fault Diagnosis of Hybrid Systems, IEEE Transactions on Systems, Man and Cybernetics, Part B (Cybernetics), vol.35, issue.6, pp.1225-1240, 2005. ,
DOI : 10.1109/TSMCB.2005.850178
Fault Diagnosis of Hybrid Systems, Proceedings of the 2005 IEEE International Symposium on, Mediterrean Conference on Control and Automation Intelligent Control, 2005., pp.832-837, 2005. ,
DOI : 10.1109/.2005.1467122
Model-Based Diagnosis of Hybrid Systems, IEEE Transactions on Systems, Man, and Cybernetics - Part A: Systems and Humans, vol.37, issue.3, pp.348-361, 2007. ,
DOI : 10.1109/TSMCA.2007.893487
Robust state estimation and fault diagnosis for uncertain hybrid nonlinear systems, Nonlinear Analysis: Hybrid Systems, vol.1, issue.1, pp.2-15, 2007. ,
DOI : 10.1016/j.nahs.2007.01.002
Fault detection and isolation for stochastic linear hybrid systems, Proceedings of the 48h IEEE Conference on Decision and Control (CDC) held jointly with 2009 28th Chinese Control Conference, pp.2622-2627, 2009. ,
DOI : 10.1109/CDC.2009.5400687
Robust fault tolerant tracking control with application to hybrid nonlinear systems, IET Control Theory & Applications, vol.3, issue.2, pp.211-224, 2009. ,
DOI : 10.1049/iet-cta:20080015
URL : https://hal.archives-ouvertes.fr/hal-00710749
Failure detection and reconstruction in switched nonlinear systems, Nonlinear Analysis: Hybrid Systems, vol.3, issue.3, pp.225-238, 2009. ,
DOI : 10.1016/j.nahs.2009.01.013
Robust Fault Detection Based-Observer for Linear Switched Systems, Proceedings of the 3rd IFAC Conference on Analysis and Design of Hybrid Systems, 2009. ,
DOI : 10.3182/20090916-3-ES-3003.00067
Design of robust fault detection filter for hybrid switched systems, 2010 Conference on Control and Fault-Tolerant Systems (SysTol), pp.161-166, 2010. ,
DOI : 10.1109/SYSTOL.2010.5675996
Robust estimation and fault detection and isolation algorithms for stochastic linear hybrid systems with unknown fault input, IET Control Theory & Applications, vol.5, issue.12, pp.1353-1368, 2011. ,
DOI : 10.1049/iet-cta.2010.0287
HOSM Observer for a Class of Non-Minimum Phase Causal Nonlinear MIMO Systems, IEEE Transactions on Automatic Control, vol.55, issue.2, pp.543-548, 2010. ,
DOI : 10.1109/TAC.2009.2037478
Strong detectability and observers, Linear Algebra and its Applications, vol.50, pp.353-368, 1983. ,
DOI : 10.1016/0024-3795(83)90061-7
Control theory for linear systems, 2001. ,
High-order sliding-mode observation for linear systems with unknown inputs, Nonlinear Analysis: Hybrid Systems, vol.5, issue.2, pp.189-205, 2011. ,
DOI : 10.1016/j.nahs.2010.09.003
Algebraic switching time identification for a class of linear hybrid systems, Nonlinear Analysis: Hybrid Systems, vol.5, issue.2, pp.233-241, 2011. ,
DOI : 10.1016/j.nahs.2010.07.003
URL : https://hal.archives-ouvertes.fr/inria-00520410
A strong controllability and observability in linear multivariable control, IEEE Transactions on Automatic Control, vol.21, issue.5, pp.761-764, 1976. ,
DOI : 10.1109/TAC.1976.1101364
Nonlinear Control Systems, 1996. ,
Partial unknown input reconstruction for linear systems, Automatica, vol.47, issue.8, pp.1751-1756, 2011. ,
DOI : 10.1016/j.automatica.2011.03.002
Exact Differentiation of Signals With Unbounded Higher Derivatives, IEEE Transactions on Automatic Control, vol.57, issue.4, pp.1076-1080, 2012. ,
DOI : 10.1109/TAC.2011.2173424
High-order sliding modes: differentiation and output-feedback control, International Journal of Control, vol.76, pp.9-10924, 2003. ,
Robust exact finite-time output based control using high-order sliding modes, International Journal of Systems Science, vol.2, issue.11, pp.1847-1857, 2011. ,
DOI : 10.1002/rnc.1397
Support Theory for Preconditioning, SIAM Journal on Matrix Analysis and Applications, vol.25, issue.3, pp.694-717, 2003. ,
DOI : 10.1137/S0895479801390637
