Topology design of surgical reconfigurable robots by interval analysis - Archive ouverte HAL Access content directly
Conference Papers Year : 2009
An automated design generation algorithm for a serial kinematic chain is presented for the reconfigurable robot used in a novel endoluminal surgical procedure (European Union project ARES). The algorithm produces the possible topologies, given the design constraints, desired performance, and available modules, such that all constraints are satisfied for every point in the desired workspace. This is achieved through the use of interval analysis methods and branch-and-bound loop that searches through the end-effector pose and the design parameter spaces. The resulting algorithm is demonstrated through an example of a serial chain manipulator made of the reconfigurable modules of the surgical robot for the application. The results are presented and discussed.
Dates and versions
hal-00987475 , version 1 (06-05-2014)
Identifiers
Cite
Denny Oetomo, David Daney, Kanako Harada, Jean-Pierre Merlet, Arianna Menciassi, et al.. Topology design of surgical reconfigurable robots by interval analysis. IEEE International Conference on Robotics and Automation (ICRA), 2009, Kobe, Japan. pp.3085--3090, ⟨10.1109/ROBOT.2009.5152407⟩. ⟨hal-00987475⟩
134 View
0 Download
Share
