Certified workspace analysis of 3RRR planar parallel flexure mechanism - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper addresses the problem of certifying the performance of a precision flexure-base mechanism design with respect to the given constraints. Due to the stringent requirements associated with the applications of flexure-based precision mechanisms, it is necessary to be able to evaluate and certify the performance at the design stage, taking into account the possible sources of errors: such as fabrication tolerance and modeling inaccuracies in flexure joints. An interval-based method is proposed to certify whether various constraints are satisfied for all points within a required workspace. This paper presents the interval-based methodology and its implementation on a planar 3RRR parallel flexure-based manipulator.
Fichier non déposé
hal-00987549 , version 1 (06-05-2014)
Denny Oetomo, David Daney, Bijan Shirinzadeh, Jean-Pierre Merlet. Certified workspace analysis of 3RRR planar parallel flexure mechanism. IEEE International Conference on Robotics and Automation (ICRA), 2008, Pasadena, United States. pp.3838--3843, ⟨10.1109/ROBOT.2008.4543800⟩. ⟨hal-00987549⟩
138 Consultations
0 Téléchargements
