Journal articles
Clique-transversal sets and weak 2-colorings in graphs of small maximum degree
Abstract : A clique-transversal set in a graph is a subset of the vertices that meets all maximal complete subgraphs on at least two vertices. We prove that every connected graph of order n and maximum degree three has a clique-transversal set of size left perpendicular19n/30 + 2/15right perpendicular. This bound is tight, since 19n/30 - 1/15 is a lower bound for infinitely many values of n. We also prove that the vertex set of any connected claw-free graph of maximum degree at most four, other than an odd cycle longer than three, can be partitioned into two clique-transversal sets. The proofs of both results yield polynomial-time algorithms that find corresponding solutions.
Document type :
Journal articles
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-00988213
Contributor : Service Ist Inria Sophia Antipolis-Méditerranée / I3s Connect in order to contact the contributor
Submitted on : Wednesday, May 7, 2014 - 4:23:29 PM
Last modification on : Wednesday, December 11, 2019 - 5:10:02 PM
Long-term archiving on: : Thursday, August 7, 2014 - 11:40:32 AM
File
1273-4292-1-PB.pdf
Identifiers
Collections
Citation
Gábor Bacsó, Zsolt Tuza. Clique-transversal sets and weak 2-colorings in graphs of small maximum degree. Discrete Mathematics and Theoretical Computer Science, DMTCS, 2009, Vol. 11 no. 2 (2), pp.15--24. ⟨10.46298/dmtcs.453⟩. ⟨hal-00988213⟩
Share
Metrics
Record views
85
Files downloads
626
