Parametric optimization of hybrid car engines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optimization and Engineering Année : 2004
Ahmed Ketfi-Cherif
  • Fonction : Auteur
Dirk von Wissel
  • Fonction : Auteur
Claudia Sagastizábal
  • Fonction : Auteur
Hasnaa Zidani
We consider the problem of optimal design of hybrid car engines which combine thermal and electric power. The optimal configuration of the different motors composing the hybrid system involves the choice of certain design parameters. For a given configuration, the goal is to minimize the fuel consumption along a trajectory. This is an optimal control problem with one state variable. The simultaneous optimization of design parameters and trajectories can be formulated as a bilevel optimization problem. The lower level computes the optimal control for a given architecture. The higher level seeks for the optimal design parameters by solving a nonconvex nonsmooth optimization problem with a bundle method.
hal-00988792 , version 1 (09-05-2014)
Frédéric Bonnans, Ahmed Ketfi-Cherif, Dirk von Wissel, Claudia Sagastizábal, Hasnaa Zidani. Parametric optimization of hybrid car engines. Optimization and Engineering, 2004, 5 (4), pp.395-415. ⟨10.1023/B:OPTE.0000042032.47856.e5⟩. ⟨hal-00988792⟩
Collections
ENSTA UMA_ENSTA
93 Consultations
0 Téléchargements
