Modal intervals revisited : a mean-value extension to generalized intervals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
The modal intervals theory deals with quantified propositions in AE-form, i.e. universal quantifiers precede existential ones, where variables are quantified over continuous domains and with equality constraints. It allows to manipulate such quantified propositions computing only with bounds of intervals. A simpler formulation of this theory is presented. Thanks to this new framework, a mean-value extension to generalized intervals (intervals whose bounds are not constrained to be ordered) is defined. Its application to the validation of quantified propo- sitions is illustrated
Fichier non déposé
hal-00990048 , version 1 (13-05-2014)
  • HAL Id : hal-00990048 , version 1
Alexandre Goldsztejn, David Daney, Michel Rueher, Patrick Taillibert. Modal intervals revisited : a mean-value extension to generalized intervals. In International Workshop on Quantification in Constraint Programming (International Conference on Principles and Practice of Constraint Programming, CP-2005), Oct 2005, Barcelona, Spain. ⟨hal-00990048⟩
446 Consultations
0 Téléchargements
