Symmetry and dependence properties within a semiparametric family of bivariate copulas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Nonparametric Statistics Année : 2002
In this paper, we study a semiparametric family of bivariate copulas. The family is generated by an univariate function, determining the symmetry (radial symmetry, joint symmetry) and dependence property (quadrant dependence, total positivity, ...) of the copulas. We provide bounds on different measures of association (such as Kendall's Tau, Spearman's Rho) for this family and several choices of generating functions allowing to reach these bounds.
copule_complet3.pdf (172.08 Ko) Télécharger le fichier
hal-00990374 , version 1 (13-05-2014)
Cécile Amblard, Stéphane Girard. Symmetry and dependence properties within a semiparametric family of bivariate copulas. Journal of Nonparametric Statistics, 2002, 14 (6), pp.715-727. ⟨10.1080/10485250215322⟩. ⟨hal-00990374⟩
171 Consultations
280 Téléchargements
