Drawing planar bipartite graphs with small area, Canadian Conference on Computational Geometry (CCCG '05), pp.105-108, 2005. ,
How to draw a series-parallel digraph, International Journal of Computational Geometry & Applications, vol.4, issue.4, pp.385-402, 1994. ,
Drawing K2,n: A lower bound, Canadian Conference on Computational Geometry (CCCG '02), pp.146-148, 2002. ,
DOI : 10.1016/S0020-0190(02)00433-7
Drawing K2,n: A lower bound, Information Processing Letters, vol.85, issue.6, pp.303-305, 2003. ,
Drawing outer-planar graphs in O(n log n) area, Graph Drawing (GD '02), volume 2528 of LNCS, pp.54-65, 2002. ,
Small poly-line drawings of series-parallel graphs, Canada, 2005. ,
On small drawings of series-parallel graphs and other subclasses of planar graphs, Graph Drawing (GD '09), pp.280-291, 2010. ,
Calcul des rouages par approximation, nouvelle methode, Revue Chronometrique, vol.6, pp.186-194, 1860. ,
A note on optimal area algorithms for upward drawings of binary trees, Computational Geometry, vol.2, issue.4, pp.187-200, 1992. ,
DOI : 10.1016/0925-7721(92)90021-J
Minimum-width grid drawings of plane graphs, Computational Geometry, vol.11, issue.1, pp.29-54, 1998. ,
DOI : 10.1016/S0925-7721(98)00016-9
Book Embeddability of Series???Parallel Digraphs, Algorithmica, vol.45, issue.4, pp.531-547, 2006. ,
DOI : 10.1007/s00453-005-1185-7
Small Area Drawings of Outerplanar Graphs, Algorithmica, vol.30, issue.2, pp.25-53, 2009. ,
DOI : 10.1007/s00453-007-9117-3
Drawing Series-Parallel Graphs on Restricted Integer 3D Grids, Graph Drawing (GD '03), pp.238-246, 2003. ,
DOI : 10.1007/978-3-540-24595-7_22
Planar embeddings of planar graphs, Advances in Computing Research, pp.147-161, 1984. ,
How to draw a planar graph on a grid, Combinatorica, vol.13, issue.1, pp.41-51, 1990. ,
DOI : 10.1007/BF02122694
Parallel recognition of series-parallel graphs, Information and Computation, vol.98, issue.1, pp.41-55, 1992. ,
Straight-Line Drawings on Restricted Integer Grids in Two and Three Dimensions, Journal of Graph Algorithms and Applications, vol.7, issue.4, pp.363-398, 2003. ,
DOI : 10.7155/jgaa.00075
Straight-line drawings of outerplanar graphs in O(dn log n) area, Canadian Conference on Computational Geometry (CCCG '07), pp.225-228, 2007. ,
A lower bound on the area requirements of series-parallel graphs, Graph Theoretic Concepts in Computer Science (WG '08), pp.159-170, 2008. ,
PLANAR UPWARD TREE DRAWINGS WITH OPTIMAL AREA, International Journal of Computational Geometry & Applications, vol.06, issue.03, pp.333-356, 1996. ,
DOI : 10.1142/S0218195996000228
Straight-Line Drawings of General Trees with Linear Area and Arbitrary Aspect Ratio, International Conference on Computational Science and its Applications (ICCSA '03)He97] X. He. Grid embedding of 4-connected plane graphs. Discrete & Computational Geometry, pp.876-885339, 1997. ,
DOI : 10.1007/3-540-44842-X_89
Sur leprobì eme des courbes gauches en topologie, Fund. Math, vol.15, pp.271-283, 1930. ,
Grid Drawings of 4-Connected Plane Graphs, Discrete & Computational Geometry, vol.26, issue.1, pp.73-87, 2001. ,
DOI : 10.1007/s00454-001-0004-4
Ueber eine zahlentheoretische funktion, Journal fur die reine und angewandte Mathematik, pp.193-220, 1858. ,
Pathwidth and layered drawings of trees, International Journal of Computational Geometry & Applications, vol.14, issue.3, pp.203-225, 2004. ,
The recognition of series parallel digraphs, SIAM Journal on Computing, vol.11, issue.2, pp.298-313, 1982. ,
Uber eine eigenschaft der ebenen komplexe, Mathematische Annalen, vol.114, pp.570-590, 1937. ,
Small Grid Drawings of Planar Graphs with Balanced Bipartition, Algorithms and Computation (WALCOM '10), pp.47-57, 2010. ,
DOI : 10.1007/978-3-642-11440-3_5
