Sequence variations of the 1-2-3 conjecture and irregularity strength - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2013
Ben Seamone
Karonski, Luczak, and Thomason (2004) conjecture that, for any connected graph G on at least three vertices, there exists an edge weighting from 1, 2, 3 such that adjacent vertices receive different sums of incident edge weights. Bartnicki, Grytczuk, and Niwcyk (2009) make a stronger conjecture, that each edge's weight may be chosen from an arbitrary list of size 3 rather than 1, 2, 3. We examine a variation of these conjectures, where each vertex is coloured with a sequence of edge weights. Such a colouring relies on an ordering of E(G), and so two variations arise - one where we may choose any ordering of E(G) and one where the ordering is fixed. In the former case, we bound the list size required for any graph. In the latter, we obtain a bound on list sizes for graphs with sufficiently large minimum degree. We also extend our methods to a list variation of irregularity strength, where each vertex receives a distinct sequence of edge weights.
2123-7662-1-PB.pdf (305.28 Ko) Télécharger le fichier
hal-00990603 , version 1 (13-05-2014)
Ben Seamone, Brett Stevens. Sequence variations of the 1-2-3 conjecture and irregularity strength. Discrete Mathematics and Theoretical Computer Science, 2013, Vol. 15 no. 1 (1), pp.15--28. ⟨10.46298/dmtcs.635⟩. ⟨hal-00990603⟩
Collections
TDS-MACS
74 Consultations
822 Téléchargements
