List edge and list total colorings of planar graphs without non-induced 7-cycles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2013
Giving a planar graph G, let χ'l(G) and χ''l(G) denote the list edge chromatic number and list total chromatic number of G respectively. It is proved that if G is a planar graph without non-induced 7-cycles, then χ'l(G)≤Δ(G)+1 and χ''l(G)≤Δ(G)+2 where Δ(G)≥7.
1775-7769-1-PB.pdf (224.5 Ko) Télécharger le fichier
hal-00990609 , version 1 (13-05-2014)
Aijun Dong, Guizhen Liu, Guojun Li. List edge and list total colorings of planar graphs without non-induced 7-cycles. Discrete Mathematics and Theoretical Computer Science, 2013, Vol. 15 no. 1 (1), pp.101--106. ⟨10.46298/dmtcs.629⟩. ⟨hal-00990609⟩
Collections
TDS-MACS
74 Consultations
829 Téléchargements
