Coloring Vertices and Faces of Locally Planar Graphs, Graphs and Combinatorics, vol.22, issue.3, pp.289-295, 2006. ,
DOI : 10.1007/s00373-006-0653-4
Graph Theory with Applications, 1976. ,
DOI : 10.1007/978-1-349-03521-2
Solution of Ringel's problems on the vertex-face coloring of plane graphs and on the coloring of 1-planar graphs, Metody Diskret. Analiz, vol.41, pp.12-26, 1984. ,
A new proof of the 6 color theorem, Journal of Graph Theory, vol.23, issue.4, pp.507-521, 1995. ,
DOI : 10.1002/jgt.3190190406
Acyclic colouring of 1-planar graphs, Discrete Applied Mathematics, vol.114, issue.1-3, pp.29-41, 2001. ,
DOI : 10.1016/S0166-218X(00)00359-0
The height of a cycle of length 4 in 1-planar graphs with minimum degree 5 without triangles, Diskretn. Anal. Issled. Oper, vol.15, issue.1, pp.11-16, 2008. ,
The structure of 1-planar graphs, Discrete Mathematics, vol.307, issue.7-8, pp.854-865, 2007. ,
DOI : 10.1016/j.disc.2005.11.056
On local structure of 1-planar graphs of minimum degree 5 and girth 4, Discussiones Mathematicae Graph Theory, vol.29, issue.2, pp.385-400, 2009. ,
DOI : 10.7151/dmgt.1454
On local properties of 1-planar graphs with high minimum degree, Ars Math. Contemp, vol.4, issue.2, pp.245-254, 2011. ,
Minimal Obstructions for 1-Immersions and Hardness of 1-Planarity Testing, Lecture Notes in Comput. Sci, vol.5417, pp.302-312, 2009. ,
DOI : 10.1007/978-3-642-00219-9_29
On local properties of 1-planar graphs with specified minimum degree and girth, The Fifth Workshop, Graph Embeddings and Maps on Surfaces, 2009. ,
Optimal 1-planar graphs which triangulate other surfaces, Discrete Mathematics, vol.310, issue.1, pp.6-11, 2010. ,
DOI : 10.1016/j.disc.2009.07.016
Coupled choosability of plane graphs, Journal of Graph Theory, vol.25, issue.1, pp.27-44, 2008. ,
DOI : 10.1002/jgt.20292
On edge colorings of 1-planar graphs without adjacent triangles, Information Processing Letters, vol.112, issue.4, 2011. ,
DOI : 10.1016/j.ipl.2011.10.021
On edge colorings of 1-planar graphs without chordal 5-cycles, Ars Combin, 2011. ,
On edge colorings of 1-planar graphs, Information Processing Letters, vol.111, issue.3, pp.124-128, 2011. ,
DOI : 10.1016/j.ipl.2010.11.001
Structural properties of 1-planar graphs and an application to acyclic edge coloring, Scientia Sinica Mathematica, vol.40, issue.10, pp.1025-1032, 2010. ,
Edge coloring of triangle-free 1-planar graphs, J. Shandong Univ. Nat. Sci, vol.45, issue.6, pp.15-17, 2010. ,
List edge and list total coloring of 1-planar graphs, Frontiers of Mathematics in China, vol.9, issue.6, 2010. ,
DOI : 10.1007/s11464-012-0184-7
Light subgraphs in the family of 1-planar graphs with high minimum degree, Acta Mathematica Sinica, English Series, vol.24, issue.4, p.2011 ,
DOI : 10.1007/s10114-011-0439-3
On (p, 1)-total labelling of 1-planar graphs, Central European Journal of Mathematics, vol.9, issue.6, 2011. ,
DOI : 10.2478/s11533-011-0092-1
