StaDy: Deep Integration of Static and Dynamic Analysis in Frama-C - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2014
We present StaDy, a new integration of the concolic test generator PathCrawler within the software analysis platform Frama- C. When executing a dynamic analysis of a C code, the integrated test generator also exploits its formal specification, written in an executable fragment of the acsl specification language shared with other analyzers of Frama-C. The test generator provides the user with accurate verdicts, that other Frama-C plugins can reuse to improve their own analyses. This tool is designed to be the foundation stone of static and dynamic analysis combinations in the Frama-C platform. Our first experiments confirm the benefits of such a deep integration of static and dynamic analysis within the same platform.
PKGJ14rr.pdf (173.86 Ko) Télécharger le fichier
hal-00992159 , version 1 (16-05-2014)
  • HAL Id : hal-00992159 , version 1
Guillaume Petiot, Nikolai Kosmatov, Alain Giorgetti, Jacques Julliand. StaDy: Deep Integration of Static and Dynamic Analysis in Frama-C. 2014. ⟨hal-00992159⟩
431 Consultations
417 Téléchargements
