Early Deciding Synchronous Renaming in O( logf ) Rounds or Less - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Renaming is a fundamental problem in distributed computing, in which a set of n processes need to pick unique names from a namespace of limited size. In this paper, we present the first early-deciding upper bounds for synchronous renaming, in which the running time adapts to the actual number of failures f in the execution. We show that, surprisingly, renaming can be solved in constant time if the number of failures √ f is limited to O( n), while for general f ≤ n − 1 renaming can always be solved in O(log f ) communication rounds. In the wait-free case, i.e. for f = n − 1, our upper bounds match the Ω(log n) lower bound of Chaudhuri et al.
14.pdf (178.05 Ko) Télécharger le fichier
hal-00992782 , version 1 (19-05-2014)
  • HAL Id : hal-00992782 , version 1
Dan Alistarh, Hagit Attiya, Rachid Guerraoui, Corentin Travers. Early Deciding Synchronous Renaming in O( logf ) Rounds or Less. SIROCCO, 2012, Unknown, pp.195-206. ⟨hal-00992782⟩
Collections
CNRS
80 Consultations
112 Téléchargements
