Poster communications
Speech Cine SSFP with optical microphone synchronization and motion compensated reconstruction
Abstract : Dynamic imaging of the vocal tact is important for modeling speech through the acoustic-articulatory relation. The average duration of each sound is about 80ms. Movements of each articulator, in particular the tongue, should be captured with sufficient precision. Current clinical techniques use X-ray video fluoroscopy which involves ionizing radiation. Real-time MRI allows direct recording of speech motion [1] but is intrinsically limited in terms of resolution and SNR. Synchronization of MRI with an acoustic device is possible [2] but requires motion of vocal system to be highly reproducible. In this work we propose an optimized setup for achieving dynamic MRI of speech with high spatial and temporal resolution based on a combination of: an MR-compatible acoustic device allowing simultaneous recording of speech during MRI; and a retrospectively gated, motion-compensated image reconstruction that can deal with the variability of the subject repeating the same sentence over the acquisition.
Complete list of metadata
https://hal.inria.fr/hal-00994526
Contributor : Emmanuel Vincent Connect in order to contact the contributor
Submitted on : Tuesday, October 6, 2015 - 10:03:10 PM
Last modification on : Thursday, January 20, 2022 - 5:27:04 PM
Long-term archiving on: : Thursday, January 7, 2016 - 11:03:43 AM
File
vuissoz_ISMRM14.pdf
Identifiers
  • HAL Id : hal-00994526, version 1
Citation
Pierre-André Vuissoz, Freddy Odille, Yves Laprie, Emmanuel Vincent, Gabriela Hossu, et al.. Speech Cine SSFP with optical microphone synchronization and motion compensated reconstruction. ISMRM Workshop on Motion Correction in MRI, Jul 2014, Tromso, Norway. 2014. ⟨hal-00994526⟩
Share
Metrics
Les métriques sont temporairement indisponibles
