Toric Border Basis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Toric Border Basis
Bernard Mourrain
Philippe Trebuchet
  • Fonction : Auteur
  • PersonId : 833470
We extend the theory and the algorithms of Border Bases to systems of Laurent polynomial equations, defining ''toric'' roots. Instead of introducing new variables and new relations to saturate by the variable inverses, we propose a more efficient approach which works directly with the variables and their inverse. We show that the commutation relations and the inversion relations characterize toric border bases. We explicitly describe the first syzygy module associated to a toric border basis in terms of these relations. Finally, a new border basis algorithm for Laurent polynomials is described and a proof of its termination is given for zero-dimensional toric ideals.
paper.pdf (193.07 Ko) Télécharger le fichier
hal-00994683 , version 1 (03-06-2014)
Bernard Mourrain, Philippe Trebuchet. Toric Border Basis. ISSAC'14 - International Symposium on Symbolic and Algebraic Computation, Jul 2014, Kobe, Japan. pp.343-350, ⟨10.1145/2608628.2608652⟩. ⟨hal-00994683⟩
226 Consultations
151 Téléchargements
