Journal articles
Ciruvis: a web-based tool for rule networks and interaction detection using rule-based classifiers
Susanne Bornelöv 1 Simon Marillet 1, 2 Jan Komorowski 1, 3, *
* Corresponding author
2 ABS - Algorithms, Biology, Structure
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Background
The use of classification algorithms is becoming increasingly important for the field of computational biology. However, not only the quality of the classification, but also its biological interpretation is important. This interpretation may be eased if interacting elements can be identified and visualized, something that requires appropriate tools and methods.
Results
We developed a new approach to detecting interactions in complex systems based on classification. Using rule-based classifiers, we previously proposed a rule network visualization strategy that may be applied as a heuristic for finding interactions. We now complement this work with Ciruvis, a web-based tool for the construction of rule networks from classifiers made of IF-THEN rules. Simulated and biological data served as an illustration of how the tool may be used to visualize and interpret classifiers. Furthermore, we used the rule networks to identify feature interactions, compared them to alternative methods, and computationally validated the findings.
Conclusions
Rule networks enable a fast method for model visualization and provide an exploratory heuristic to interaction detection. The tool is made freely available on the web and may thus be used to aid and improve rule-based classification.
Complete list of metadata
https://hal.inria.fr/hal-00995110
Contributor : Ed. BMC Connect in order to contact the contributor
Submitted on : Thursday, May 22, 2014 - 5:05:29 PM
Last modification on : Sunday, May 1, 2022 - 3:15:09 AM
Long-term archiving on: : Friday, August 22, 2014 - 1:20:25 PM
Identifiers
  • HAL Id : hal-00995110, version 1
Collections
Citation
Susanne Bornelöv, Simon Marillet, Jan Komorowski. Ciruvis: a web-based tool for rule networks and interaction detection using rule-based classifiers. BMC Bioinformatics, BioMed Central, 2014, 15 (1), pp.139. ⟨hal-00995110⟩
Share
Metrics
Record views
86
Files downloads
154
