Physical modeling of the densification of snow/firn and ice in the upper part of polar ice sheets, Physics of Ice Core Records, pp.285-305, 2000. ,
Pleistocene water intrusions from the Mediterranean and Caspian seas into the Black Sea, Nat. Geosci, vol.4, pp.4-11, 2012. ,
800,000 years of abrupt climate variability, Science, vol.334, pp.347-351, 2011. ,
An optimized multi-proxy, multi-site Antarctic ice and gas orbital chronology (AICC2012): 120-800 ka, Clim. Past, vol.9, pp.1715-1731, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00995643
The Dole effect and its variation during the last 130,000 years as measured in the Vostok core, Global Biogeochem. Cy, vol.8, pp.363-376, 1994. ,
Were last glacial climate events simultaneous between Greenland and France? A quantitative comparison using non-tuned chronologies, J. Quaternary Sci, vol.25, pp.387-394, 2010. ,
and INTIMATE members: Synchronisation of palaeoenvironmental records over the last 60,000 years, and an extended INTIMATE event stratigraphy to 48,000 b2k, Quaternary Sci. Rev, vol.36, pp.2-10, 2012. ,
Timing of millennial-scale climate change in Antarctica and Greenland during the last glacial period, Science, vol.291, pp.109-112, 2001. ,
Asynchrony of Antarctic and Greenland climate change during the last glacial period, Nature, vol.394, pp.739-743, 1998. ,
Synchronization of ice core records via atmospheric gases, Clim. Past, vol.3, pp.325-330, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330725
NALPS: a precisely dated European climate record 120-60 ka, Clim. Past, vol.7, pp.1247-1259, 2011. ,
A twoparameter stochastic process for Dansgaard-Oeschger events, Paleoceanography, vol.26, p.3214, 2011. ,
Complete Terrestrial Radiocarbon Record for 11, Science, vol.338, pp.370-374, 2012. ,
Rapid variations in atmospheric methane concentration during the past 110 000 years, Science, vol.273, pp.1087-1091, 1996. ,
Regional imprints of millennial variability during the MIS 3 period around Antarctica, Quaternary Sci. Rev, vol.7, pp.1728-1731, 2003. ,
Synchronizing EDML and NorthGRIP ice cores using ? 18 O of atmospheric oxygen (? 18 O atm ) and CH 4 measurements over MIS5 (80-123 kyr), Quaternary Sci. Rev, vol.29, pp.222-234, 2010. ,
Glacialinterglacial dynamics of Antarctic firn columns: comparison between simulations and ice core air-? 15 N measurements, Clim. Past, vol.9, pp.983-999, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00861133
Ice Age Terminations, Science, vol.326, pp.248-252, 2009. ,
Synchronous changes in atmospheric CH 4 and Greenland climate between 40 and 8 kyr BP, Nature, vol.366, pp.443-445, 1993. ,
, Past temperatures directly from the Greenland ice sheet, vol.282, pp.268-271, 1998.
, A new Greenland deep ice core, vol.218, pp.1273-1277, 1982.
North Atlantic climatic oscillations revealed by deep Greenland ice cores, in: Climate processes and climate sensitivity, Am. Geophys, pp.288-298, 1984. ,
Changes in the atmospheric CH 4 gradient between Greenland and Antarctica during the Last Glacial and the transition to the Holocene, Geophys. Res. Lett, vol.27, pp.1005-1008, 2000. ,
Anomalous flow below 2700 m in the EPICA Dome C ice core detected using ? 18 O of atmospheric oxygen measurements, Clim. Past, vol.3, pp.341-353, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330756
Stalagmite evidence for the precise timing of North Atlantic cold events during the early last glacial, Geology, vol.35, pp.77-80, 2007. ,
Physical setting and tephrochronology of the summit caldera ice record at Mount Moulton, West Antarctica, Geol. Soc. Am. Bull, vol.120, pp.195-198, 2004. ,
Timing and climatic impact of Greenland interstadials recorded in stalagmites from northern Turkey, Geophys. Res. Lett, vol.36, p.19707, 2009. ,
N 2 O and CH 4 variations during the last glacial epoch: Insight into global processes, Global Biogeochem. Cy, vol.18, p.1020, 2004. ,
Modeling the densification of polar firn including heat diffusion: Application to close-off characteristics and gas isotopic fractionation for Antarctica and Greenland sites, J. Geophys. Res, vol.108, pp.101-1018, 2003. ,
Comparison of the oxygen isotope records from the GISP2 and GRIP Greenland ice cores, Nature, vol.366, pp.552-554, 1993. ,
Isotope calibrated Greenland temperature record over Marine Isotope Stage 3 and its relation to CH 4, Earth Planet. Sc. Lett, vol.243, pp.504-519, 2006. ,
Ice thinning, upstream advection, and non-climatic biases for the upper 89 % of the EDML ice core from a nested model of the Antarctic ice sheet, Clim. Past, vol.3, pp.577-589, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00298184
, Science, vol.317, pp.793-796, 2007.
Northern Hemisphere forcing of climatic cycles in Antarctica over the past 360 000 years, Nature, vol.448, pp.912-916, 2007. ,
URL : https://hal.archives-ouvertes.fr/insu-00376337
Bayesian Glaciological Modelling to quantify uncertainties in ice core chronologies, Quaternary Sci. Rev, vol.30, pp.2961-2975, 2011. ,
Rapid changes in ice core gas records -Part 1: On the accuracy of methane synchronisation of ice cores, Clim. Past Discuss, vol.6, pp.1453-1471, 2010. ,
Quantification of rapid temperature change during DO event 12 and phasing with methane inferred from air isotopic measurements, Earth Planet. Sc. Lett, vol.225, pp.1733-1748, 2004. ,
The Antarctic ice core chronology (AICC2012) ,
URL : https://hal.archives-ouvertes.fr/hal-00995618
Firn-air ? 15 N in modern polar sites and glacial-interglacial ice: a model-data mismatch during glacial periods in Antarctica?, Quaternary Sci. Rev, vol.25, pp.49-62, 2006. ,
URL : https://hal.archives-ouvertes.fr/insu-00375513
What drives the millennial and orbital variations of ? 18 O atm ?, Quaternary Sci. Rev, vol.29, pp.235-246, 2010. ,
16 ? C Rapid temperature variation in Central Greenland 70,000 years ago, Science, vol.286, pp.934-937, 1999. ,
Glaciochemistry of polar ice cores: A review, Rev. Geophys, vol.35, pp.219-243, 1997. ,
URL : https://hal.archives-ouvertes.fr/insu-00502145
Consistent dating for Antarctic and Greenland ice cores, Quaternary Sci. Rev, vol.29, pp.8-20, 2010. ,
URL : https://hal.archives-ouvertes.fr/insu-00562239
A Pliocene-Pleistocene stack of 57 globally distributed benthic 18 O records, Paleoceanography, vol.20, p.1003, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01103826
, Contraintes chronologiques et biogeochimiques grace au methane dans la glace naturelle: une application aux forages du projet EPICA, 2007.
URL : https://hal.archives-ouvertes.fr/tel-00329799
New constraints on the gas age-ice age difference along the EPICA ice cores, 0-50 kyr, Clim. Past, vol.3, pp.527-540, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330728
Orbital and millennial-scale features of atmospheric CH 4 over the past 800 000 years, Nature, vol.453, pp.383-386, 2008. ,
URL : https://hal.archives-ouvertes.fr/insu-00379657
Rapid and slow reorganisation of the Northern Hemisphere hydrological cycle during the last glacial period as derived from the GRIP ice core deuterium-excess record, Science, vol.309, pp.118-121, 2005. ,
Multidecadal variability of atmospheric methane, J. Geophys. Res, vol.116, p.2007, 2011. ,
NGRIP Community Members: High-resolution record of Northern Hemisphere climate extending into the last interglacial period, Quaternary Sci. Rev, vol.25, pp.147-151, 2004. ,
Dating the Vostok ice core by an inverse method, J. Geophys. Res, vol.106, pp.31837-31852, 2001. ,
New modeling of the Vostok ice flow line and implication for the glaciological chronology of the Vostok ice core, J. Geophys. Res, vol.109, pp.1-14, 2004. ,
The EDC3 chronology for the EPICA Dome C ice core, Clim. Past, vol.3, pp.485-497, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330730
Volcanic synchronisation between the EPICA Dome C and Vostok ice cores (Antarctica) 0-145 kyr BP, Clim. Past, vol.8, pp.1031-1045, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00725778
On the gas-ice depth difference ( depth) along the EPICA Dome C ice core, Clim. Past, vol.8, pp.1239-1255, 2012. ,
URL : https://hal.archives-ouvertes.fr/insu-00843989
Synchronous Change of Atmospheric CO 2 and Antarctic Temperature During the Last Deglacial Warming, Science, vol.339, pp.1060-1063, 2013. ,
URL : https://hal.archives-ouvertes.fr/cea-00862616
The last deglaciation: timing the bipolar seesaw, Clim. Past, vol.7, pp.671-683, 2011. ,
URL : https://hal.archives-ouvertes.fr/insu-00649687
Direct north-south synchronization of abrupt climate change record in ice cores using Beryllium 10, Clim. Past, vol.399, pp.541-547, 1999. ,
A new Greenland ice core chronology for the last glacial termination, J. Geophys. Res, vol.111, p.6102, 2006. ,
Synchronization of the NGRIP, GRIP, and GISP2 ice cores across MIS 2 and palaeoclimatic implications, Quaternary Sci. Rev, vol.27, pp.18-28, 2008. ,
EDML1": a chronology for the EPICA deep ice core from Dronning Maud Land, Antarctica, over the last 150 000 years, Clim. Past, vol.3, pp.475-484, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330729
Glacial-interglacial and millennial-scale variations in the atmospheric nitrous oxide concentration during the last 800,000 years, Quaternary Sci. Rev, vol.29, pp.182-192, 2010. ,
A refined TALDICE-1a age scale from 55 to 112 ka before present for the Talos Dome ice core based on highresolution methane measurements, Clim. Past, vol.7, pp.1001-1009, 2011. ,
Age scale of the air in the summit ice: implication for glacial-interglacial temperature change, J. Geophys. Res, vol.102, 1997. ,
Synchronisation of the EDML and EDC ice cores for the last 52 kyr by volcanic signature matching, Clim. Past, vol.3, pp.367-374, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330727
Volcanic synchronisation of the EPICA-DC and TALDICE ice cores for the last 42 kyr BP, Clim. Past, vol.8, pp.509-517, 2012. ,
Timing of abrupt climate change at the end of the Younger Dryas interval from thermally fractionated gases in polar ice, Nature, vol.391, pp.141-146, 1998. ,
40 Ar/ 39 Ar, K-Ar and 230 Th-238 U dating of the Laschamp excursion: A radioisotopic tie-point for ice core and climate chronologies, Earth Planet. Sci. Lett, vol.286, pp.80-88, 2009. ,
? 15 N of N 2 in air trapped in polar ice: a tracer of gas transport in the firn and a possible constraint on ice age-gas age differences, J. Geophys. Res, vol.97, pp.15683-15697, 1992. ,
The attenuation of fast atmospheric CH 4 variations recorded in polar ice cores, Geophys. Res. Lett, vol.30, p.1571, 2003. ,
Atmospheric Methane and Nitrous Oxide of the Late Pleistocene from Antarctic Ice Cores, Science, vol.310, pp.1317-1321, 2005. ,
URL : https://hal.archives-ouvertes.fr/insu-00374939
Synchronous Climate Changes in Antarctica and the North Atlantic, Science, vol.282, pp.92-95, 1998. ,
Expression of the bipolar seesaw in Antarctic climate records during the last deglaciation, Nat. Geosci, vol.4, pp.46-49, 2011. ,
URL : https://hal.archives-ouvertes.fr/insu-00647558
A minimum thermodynamic model for the bipolar seesaw, Paleoceanography, vol.18, p.920, 2003. ,
Chronology of the Vostok ice core constrained by O 2 /N 2 ratios of occluded air, and its implication for the Vostok climate records, Quaternary Sci. Rev, vol.27, pp.1093-1106, 2008. ,
A 60 000 year Greenland stratigraphic ice core chronology, Clim. Past, vol.4, pp.47-57, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00330738
Direct linking of Greenland and Antarctic ice cores at the Toba eruption (74 ka BP), Clim. Past, vol.9, pp.749-766, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-02396042
Stratigraphic correlations between the EPICA-Dome C and Vostok ice cores showing the relative variations of snow accumulation over the past 45 kyr, J. Geophys. Res, vol.109, p.8101, 2004. ,
Duration of Greenland Stadial 22 and ice-gas age from counting of annual layers in Greenland NGRIP ice core, Clim. Past, vol.8, pp.1839-1847, 2012. ,
Global distribution of centennial-scale records for Marine Isotope Stage (MIS) 3: a database, Quaternary Sci. Rev, vol.21, pp.1185-1212, 2002. ,
A synchronized dating of three Greenland ice cores throughout the Holocene, J. Geophys. Res, vol.111, p.13102, 2006. ,
An annual layer counted EDML time scale covering the past 16700 years, Geophysical Research Abstracts, vol.14, pp.2012-13043, 2012. ,
Transferring radiometric dating of the last interglacial sea level high stand to marine and ice core records, Earth Planet. Sci. Lett, vol.265, pp.183-194, 2008. ,
URL : https://hal.archives-ouvertes.fr/insu-00381121
Millennial-and orbital-scale changes in the East Asian monsoon over the past 224,000 years, Nature, vol.451, pp.1733-1748, 2008. ,
Glacial terminations as southern warmings without northern control, Nat. Geosci, vol.2, pp.206-209, 2009. ,
Millennial-scale variability during the last glacial: The ice core record, Quaternary. Sci. Rev, vol.29, pp.2828-2838, 2010. ,
URL : https://hal.archives-ouvertes.fr/insu-00420831
Beryllium 10 in the Greenland Ice Core Project ice core at Summit, Greenland, J. Geophys. Res, vol.102, pp.26783-26794, 1997. ,
URL : https://hal.archives-ouvertes.fr/in2p3-00007641
Use of paleo-records in determining variability within the volcanism-climate system, Quaternary Sci. Rev, vol.19, pp.417-438, 2000. ,
