Toward a radiometric ice clock: uranium ages of the Dome C ice core, Quaternary Science Reviews, vol.30, issue.19-20, pp.2389-2397, 2011. ,
DOI : 10.1016/j.quascirev.2011.06.008
URL : https://hal.archives-ouvertes.fr/insu-00674750
Physical modeling of the densification of snow/firn and ice in the upper part of polar ice sheets, Book: Physics of Ice Core Records, pp.285-305, 2000. ,
Sea???land oxygen isotopic relationships from planktonic foraminifera and speleothems in the Eastern Mediterranean region and their implication for paleorainfall during interglacial intervals, Geochimica et Cosmochimica Acta, vol.67, issue.17, pp.3181-319910, 2003. ,
DOI : 10.1016/S0016-7037(02)01031-1
Atmospheric gas concentrations over the past century measured in air from firn at the South Pole, Nature, vol.383, issue.6597, pp.231-23510383231, 1038. ,
DOI : 10.1038/383231a0
Orbital tuning chronology for the Vostok climate record supported by trapped gas composition, Earth and Planetary Science Letters, vol.204, issue.1-2 ,
DOI : 10.1016/S0012-821X(02)00980-9
The Dole Effect and its variations during the last 130,000 years as measured in the Vostok Ice Core, Global Biogeochemical Cycles, vol.15, issue.3, pp.363-37610, 1994. ,
DOI : 10.1007/BF01323265
Combining ice core records and ice sheet models to explore the evolution of the East Antarctic Ice sheet during the Last Interglacial period, Global and Planetary Change, vol.100, pp.100278-100290, 2013. ,
DOI : 10.1016/j.gloplacha.2012.11.002
TALDICE-1 age scale of the Talos Dome deep ice core, East Antarctica, Clim. Past, vol.75194, pp.1-1610, 2011. ,
URL : https://hal.archives-ouvertes.fr/insu-00649642
Timing of Atmospheric CO2 and Antarctic Temperature Changes Across Termination III, Science, vol.299, issue.5613, pp.1728-173110, 2003. ,
DOI : 10.1126/science.1078758
Synchronising EDML and NorthGRIP ice cores using ??18O of atmospheric oxygen (??18Oatm) and CH4 measurements over MIS5 (80???123 kyr), Quaternary Science Reviews, vol.29, issue.1-2, pp.222-234, 2010. ,
DOI : 10.1016/j.quascirev.2009.07.014
Glacial???interglacial dynamics of Antarctic firn columns: comparison between simulations and ice core air-δ<sup>15</sup>N measurements, Climate of the Past, vol.9, issue.3, pp.983-999, 2013. ,
DOI : 10.5194/cp-9-983-2013
Atmospheric methane during the last four glacial-interglacial cycles: Rapid changes and their link with Antarctic temperature, Journal of Geophysical Research, vol.106, issue.D23, pp.10-1029, 2004. ,
DOI : 10.1029/GM112p0165
URL : http://onlinelibrary.wiley.com/doi/10.1029/2003JD004417/pdf
Anomalous flow below 2700 m in the EPICA Dome C ice core detected using ? 18 O of atmospheric oxygen measurements, Clim. Past, vol.35194, pp.341-35310, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330721
An ice core perspective on the age of the Matuyama???Brunhes boundary, Earth and Planetary Science Letters, vol.274, issue.1-2, pp.151-156, 2008. ,
DOI : 10.1016/j.epsl.2008.07.008
URL : https://hal.archives-ouvertes.fr/in2p3-00825234
Evidence for Obliquity Forcing of Glacial Termination II, Science, vol.424, issue.6948, pp.1527-1531, 2009. ,
DOI : 10.1038/nature01855
URL : https://hal.archives-ouvertes.fr/hal-00437279
Physical setting and tephrochronology of the summit caldera ice record at Mount Moulton, West Antarctica, Geological Society of America Bulletin, vol.120, issue.7-8, pp.796-81210, 1130. ,
DOI : 10.1130/B26140.1
Change in ice rheology during climate variations – implications for ice flow modelling and dating of the EPICA Dome C core, Climate of the Past, vol.3, issue.1, pp.155-167, 2004. ,
DOI : 10.5194/cp-3-155-2007
Stable oxygen isotopes of ice core EDML, 2010. ,
Timing and climatic impact of Greenland interstadials recorded in stalagmites from northern Turkey, Geophysical Research Letters, vol.102, issue.10, p.1970710, 1029. ,
DOI : 10.5194/cp-4-47-2008
variations during the last glacial epoch: Insight into global processes, Global Biogeochem. Cy, vol.18, pp.102010-1029, 2004. ,
Impurity controlled firn densification: a new model approach, EGU General Assembly Conference Abstracts EGU General Assembly Conference Abstracts, pp.22-27, 2012. ,
DOI : 10.3189/2013jog13j042
The modules M1QN3 and N1QN3, Program documentation, 1993. ,
Modeling the densification of polar firn including heat diffusion: Application to close-off characteristics and gas isotopic fractionation for Antarctica and Greenland sites, Journal of Geophysical Research: Atmospheres, vol.23, issue.1, pp.479210-1029, 2003. ,
DOI : 10.1017/S0022143000013277
Abstract, Journal of Glaciology, vol.25, issue.93, pp.373-385, 1980. ,
DOI : 10.3189/S0022143000015239
A model of the Earth's Dole effect, Global Biogeochemical Cycles, vol.18, issue.6, pp.100810-1029, 2004. ,
DOI : 10.1029/96GB02561
Evidence for molecular size dependent gas fractionation in firn air derived from noble gases, oxygen, and nitrogen measurements, Earth and Planetary Science Letters, vol.243, issue.1-2, pp.61-73, 2006. ,
DOI : 10.1016/j.epsl.2005.12.036
Impact of local insolation on snow metamorphism and ice core records, Physics of Ice Core Records II, pp.223-232, 2010. ,
Modeling the Climatic Response to Orbital Variations, Science, vol.207, issue.4434, pp.943-953, 1980. ,
DOI : 10.1126/science.207.4434.943
Atmospheric oxygen 18 and sea-level changes, Quaternary Science Reviews, vol.21, issue.1-3, pp.307-31410, 2002. ,
DOI : 10.1016/S0277-3791(01)00106-8
Northern Hemisphere forcing of climatic cycles in Antarctica over the past 360,000???years, Nature, vol.293, issue.7156, pp.912-91610, 1038. ,
DOI : 10.5194/cpd-3-435-2007
URL : https://hal.archives-ouvertes.fr/insu-00376337
Analyses isotopiquesàisotopiques`isotopiquesà haute précision de l'air piégé dans les glaces polaires pour la quantification des variations rapides de température: méthodes et limites, 2003. ,
A tentative reconstruction of the last interglacial and glacial inception in Greenland based on new gas measurements in the Greenland Ice Core Project (GRIP) ice core, Journal of Geophysical Research, vol.102, issue.C12, p.456310, 1029. ,
DOI : 10.1029/2001GL014192
A continuous record of temperature evolution over a sequence of Dansgaard-Oeschger events during Marine Isotopic Stage 4 (76 to 62 kyr BP), Geophysical Research Letters, vol.21, issue.D12, pp.31-2221110, 1029. ,
DOI : 10.1029/2004GL021193
URL : https://hal.archives-ouvertes.fr/hal-01103745
Large temperature variations over rapid climatic events in Greenland: a method based on air isotopic measurements, Comptes Rendus Geoscience, vol.337, issue.10-11, pp.947-956, 2005. ,
DOI : 10.1016/j.crte.2005.04.003
On the limits of Antarctic and marine climate records synchronization: Lag estimates during marine isotopic stages 5d and 5c, Paleoceanography, vol.193, issue.4, pp.10-1029, 2006. ,
DOI : 10.1016/S0012-821X(01)00515-5
Millenial scale variations of the isotopic composition of atmospheric oxygen over Marine Isotopic Stage 4, Earth and Planetary Science Letters, vol.258, issue.1-2, pp.101-113, 2007. ,
DOI : 10.1016/j.epsl.2007.03.027
What drives the millennial and orbital variations of ??18Oatm?, Quaternary Science Reviews, vol.29, issue.1-2, pp.235-246, 2010. ,
DOI : 10.1016/j.quascirev.2009.07.005
Towards orbital dating of the EPICA Dome C ice core using ?O 2, Clim. Past, vol.85194, issue.2, pp.191-20310, 2012. ,
A long-term numerical solution for the insolation quantities of??the??Earth, Astronomy & Astrophysics, vol.292, issue.4, pp.261-28510, 2004. ,
DOI : 10.1126/science.1059412
URL : https://hal.archives-ouvertes.fr/hal-00001603
O of atmospheric oxygen using a diagnostic box model for the terrestrial and marine biosphere, Journal of Geophysical Research: Oceans, vol.264, issue.C12, pp.26841-26850, 1997. ,
DOI : 10.1126/science.264.5156.239
On the potential of coupling air content and O2/N2 from trapped air for establishing an ice core chronology tuned on local insolation, Quaternary Science Reviews, vol.30, issue.23-24, pp.3280-3289, 2011. ,
DOI : 10.1016/j.quascirev.2011.07.013
A 150,000-year climatic record from Antarctic ice, Nature, vol.11, issue.6029, pp.591-59610, 1038. ,
DOI : 10.1029/GM029p0314
Contraintes chronologiques et biogeochimiques grace au methane dans la glace naturelle: une application aux forages du projet EPICA, 2007. ,
URL : https://hal.archives-ouvertes.fr/tel-00329799
New constraints on the gas age-ice age difference along the EPICA ice cores, 0?50 kyr, Clim. Past, vol.35194, pp.527-54010, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330764
Orbital and millennial-scale features of atmospheric CH4 over the past 800,000???years, Nature, vol.77, issue.7193, pp.383-386, 2008. ,
DOI : 10.1038/nature06950
URL : https://hal.archives-ouvertes.fr/insu-00379657
Changes in atmospheric CO 2 and its carbon isotopic ratio during the penultimate deglaciation, Quaternary Sci. Rev, vol.29, 1983. ,
URL : https://hal.archives-ouvertes.fr/insu-00653385
High-resolution carbon dioxide concentration record 650,000???800,000???years before present, Nature, vol.20, issue.7193, pp.379-38210, 1038. ,
DOI : 10.1038/nature06949
The Dole effect over the last two glacial-interglacial cycles, Journal of Geophysical Research: Atmospheres, vol.8, issue.D12, pp.14199-1420810, 1999. ,
DOI : 10.1007/BF00223724
A comparison of the present and last interglacial periods in six Antarctic ice cores, Clim. Past, vol.75194, pp.397-42310, 2011. ,
URL : https://hal.archives-ouvertes.fr/insu-00649670
High-resolution record of Northern Hemisphere climate extending into the last interglacial period, Nature, vol.431, pp.147-151, 2004. ,
Macintosh Program performs time-series analysis, Eos, Transactions American Geophysical Union, vol.77, issue.39, pp.379-37910, 1996. ,
DOI : 10.1029/96EO00259
Dating the Vostok ice core by an inverse method, Journal of Geophysical Research: Atmospheres, vol.102, issue.D23, pp.31837-3185210, 2001. ,
DOI : 10.1029/97JC01265
URL : http://onlinelibrary.wiley.com/doi/10.1029/2001JD900245/pdf
New modeling of the Vostok ice flow line and implication for the glaciological chronology of the Vostok ice core, Journal of Geophysical Research, vol.102, issue.2, pp.2010210-1029, 2004. ,
DOI : 10.1007/978-3-642-76059-4_9
On the gas-ice depth difference (depth) along the EPICA Dome C ice core, Clim. Past, vol.85194, pp.1239-125510, 1239. ,
URL : https://hal.archives-ouvertes.fr/insu-00843989
Volcanic synchronisation between the EPICA Dome C and Vostok ice cores (Antarctica), Clim. Past, vol.85194, pp.0-145, 1031. ,
DOI : 10.5194/cpd-7-4105-2011
URL : https://hal.archives-ouvertes.fr/hal-00725778
Climate and atmospheric history of the past 420 000 years from the Vostok ice core, pp.429-43610, 1038. ,
URL : https://hal.archives-ouvertes.fr/hal-00756651
Direct north-south synchronization of abrupt climate change record in ice cores using Beryllium 10, Clim. Past, vol.35194, pp.541-54710, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330733
A new Greenland ice core chronology for the last glacial termination, Journal of Geophysical Research, vol.26, issue.11, p.610210, 1029. ,
DOI : 10.1016/0960-1686(92)90089-4
The local insolation signature of air content in Antarctic ice. A new step toward an absolute dating of ice records, Earth and Planetary Science Letters, vol.261, issue.3-4, pp.337-349, 2007. ,
DOI : 10.1016/j.epsl.2007.06.025
URL : https://hal.archives-ouvertes.fr/insu-00377262
A methane-based time scale for Vostok ice, Quaternary Science Reviews, vol.22, issue.2-4, pp.141-15510, 2003. ,
DOI : 10.1016/S0277-3791(02)00082-3
Abstract, Annals of Glaciology, vol.39, pp.283-29210, 2004. ,
DOI : 10.3189/172756404781814023
Glacial???interglacial and millennial-scale variations in the atmospheric nitrous oxide concentration during the last 800,000 years, Quaternary Science Reviews, vol.29, issue.1-2, pp.182-192, 2010. ,
DOI : 10.1016/j.quascirev.2009.03.011
A refined TALDICE-1a age scale from 55 to 112 ka before present for the Talos Dome ice core based on highresolution methane measurements, Clim. Past, vol.75194, pp.1001-100910, 1001. ,
The age of the air in the firn and the ice at Summit, Greenland, Journal of Geophysical Research: Atmospheres, vol.60, issue.D4, pp.2831-283810, 1993. ,
DOI : 10.1016/0012-821X(82)90010-3
Synchronisation of the EDML and EDC ice cores for the last 52 kyr by volcanic signature matching, Clim. Past, vol.35194, pp.367-37410, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00330758
Volcanic synchronisation of the EPICA-DC and TALDICE ice cores for the last 42 kyr BP, Clim. Past, vol.85194, pp.509-51710, 2012. ,
Fractionation of gases in polar ice during bubble close-off: New constraints from firn air Ne, Kr and Xe observations, Earth and Planetary Science Letters, vol.244, issue.1-2, pp.474-500, 2006. ,
DOI : 10.1016/j.epsl.2006.01.032
Thermal fractionation of air in polar firn by seasonal temperature gradients, Geochemistry, Geophysics, Geosystems, vol.102, issue.19, pp.1048-102410, 2001. ,
DOI : 10.1029/96JD03382
Oxygen-18 of O2 Records the Impact of Abrupt Climate Change on the Terrestrial Biosphere, Science, vol.61, issue.3, pp.1431-143410, 2009. ,
DOI : 10.1023/B:CLIM.0000004577.17928.fa
Deep air convection in the firn at a zero-accumulation site, central Antarctica, Earth and Planetary Science Letters, vol.293, issue.3-4, pp.359-367, 2010. ,
DOI : 10.1016/j.epsl.2010.03.003
in polar ice, Journal of Geophysical Research, vol.15, issue.112, pp.5137-515010, 1989. ,
Expression of the bipolar see-saw in Antarctic climate records during the last deglaciation, Expression of the bipolar see-saw in Antarctic climate records during the last deglaciation, pp.46-4910, 1026. ,
DOI : 10.1038/ngeo1026
URL : https://hal.archives-ouvertes.fr/insu-00647558
Chronology of the Vostok ice core constrained by O2/N2 ratios of occluded air, and its implication for the Vostok climate records, Quaternary Science Reviews, vol.27, issue.11-12, pp.1093-1106, 2008. ,
DOI : 10.1016/j.quascirev.2008.02.017
The Greenland Ice Core Chronology 2005, 15???42ka. Part 2: comparison to other records, Quaternary Science Reviews, vol.25, issue.23-24, pp.3258-3267, 2006. ,
DOI : 10.1016/j.quascirev.2006.08.003
A 60 000 year Greenland stratigraphic ice core chronology, Climate of the Past, vol.4, issue.1, pp.47-5710, 2008. ,
DOI : 10.5194/cp-4-47-2008-supplement
URL : https://hal.archives-ouvertes.fr/hal-00330768
Stratigraphic correlations between the European Project for Ice Coring in Antarctica (EPICA) Dome C and Vostok ice cores showing the relative variations of snow accumulation over the past 45 kyr, Journal of Geophysical Research, vol.316, issue.22, p.810110, 1029. ,
DOI : 10.1029/2001JD900245
The Antarctic ice core chronology (AICC2012): an optimized multi-parameter and multi-site dating approach for the last 120 thousand years, Clim. Past, vol.95194, pp.1733-174810, 1733. ,
URL : https://hal.archives-ouvertes.fr/hal-00995618
Millennial- and orbital-scale changes in the East Asian monsoon over the past 224,000???years, Nature, vol.8, issue.7182, pp.1090-1093, 2008. ,
DOI : 10.1038/nature06692
Beryllium 10 in the Greenland Ice Core Project ice core at Summit, Greenland, Journal of Geophysical Research: Oceans, vol.102, issue.C12, pp.26783-2679410, 1029. ,
DOI : 10.1029/97JC00158
URL : https://hal.archives-ouvertes.fr/in2p3-00007641
Timing, Duration, and Transitions of the Last Interglacial Asian Monsoon, Timing, duration, and transitions of the Last Interglacial Asian Monsoon, pp.575-578, 2004. ,
DOI : 10.1126/science.1091220
