Outils de génération pour le moteur de rendu GigaVoxels
Enhancement of the ease of use of GigaVoxels. Possibility to mix GigaVoxels to an existing OpenGL one, and vice-versa. High-level API to add GigaVoxel to an existing OpenGL in a few lines of code (instead of a few hundred). Low-level API to set, in one line of code, raw memory, Cuda or OpenGL handles as input and/or output buffers.
